It is currently Thu Aug 07, 2025 9:25 pm
PostPosted: Sat Feb 27, 2010 3:19 pm
you have to order the gotohs with the wood (or alternative) buttons .. or at least I do, mty guy usually has some in stock .. wouldnt think of trying to pull them off and replace, but I am sure others have with some tuner makes ...
my supplier wont ship to the US, but try Shane at high mountain ...
PostPosted: Sat Feb 27, 2010 4:55 pm
First name: Tim
Last Name: Caccamise
City: Moreno Valley
Zip/Postal Code: 92557
Quote:
(all the rest of the materials on my brazilian/adi guitar don't add up to $200!)
Send me a list of your suppliers please!!!!!!!!
I have a set of the Waverly's 3 on a plate, that are going on a Martin 0 size and the are beautiful, not a flaw that I can see. The $200 bucks is steep, but the quality warrants it IMO.
Tim
PostPosted: Sat Feb 27, 2010 5:16 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I bought the Goto three on a plate gold tuners with ivoroid buttons for my BRZ parlour project. They look really good & seem to work very nicely.
I can't find them listed with SM or LMI & I don't remember where I got them. The Classic tuners on the SM site look the same except for the shafts.
http://www.stewmac.com/shop/Tuners/Guit ... uners.html
If you don't have a drilling jig, I suggest you get one. No room for error with the tuners on a plate. One good reason to use singles if you don't have the jig.
PostPosted: Sat Feb 27, 2010 5:39 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Filippo...I use the individual Gotohs unless a customer specifies Waverlies. The are excellent tuners and will probably last as long as Waverlies...at a whole lot less $$$.
I do not use the bushing that come with them. I drill the 1/4" diameter holes and the shafts rest in the blind hole in the center section of the headstock. DO get a jig! And drill holes before routing out the slots.
If you can't get what you want at LMI or SM, try Allparts. They handle a ton of Gotoh stuff.
Hank Mauel
PostPosted: Sat Feb 27, 2010 6:10 pm
Isn't Shane the GoTo Gotoh guy?
PostPosted: Sat Feb 27, 2010 6:11 pm
Filippo,
It is easy to get the buttons off these. The claw hammer method is what I use, the same as in Chris's tutorial. The shaft inside of the button is different than the grover sta-tites. It is a little wider if I remember correctly. I make buttons that fit these but you could modify any of the aftermarket buttons fairly easily. Chris's method of drilling a round hole and gluing with CA works and you can also make a mechanical bond with an end mill in a drill press, which is a little trickier but more satisfying. I think the shaft is .08 wide by .150 long with slightly rounded ends on the Gotoh's. Here is a link to a photobucket page with photos of how I make the buttons. On page 2 there is a photo of Sta-tites, gotoh, and waverly open back machines with the buttons removed and the different shafts. There is also a photo of the sled I use to hold the button in the milling machine (or drill press with compound table) vise to mill the slot.
http://s36.photobucket.com/albums/e22/b ... /?start=20
Burton
Brookline, MA.
PostPosted: Sat Feb 27, 2010 9:46 pm
If it were me, and it wasn't for a customer who was happy to pay for Waverly's, I'd use the latest generation of Grover Sta-tites, and I'd probably have Burton make a nice set of wooden buttons for them. I like the Grovers a lot better than the Gotoh Sta-tite copies. I think the Gotoh 3-on-a-plates would look way out of place on a Martinesque guitar (though they are mechanically great tuners).
Another option is Santa Cruz tuners, which are the same as the Grovers, only a slightly different base plate shape (more like Waverly's). They are available direct from Santa Cruz, and they offer a discount for guitar makers. You can get them with nice wood buttons already on them.
Todd Rose
Ithaca, NY
PostPosted: Sun Feb 28, 2010 9:43 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Anybody know where Taylor gets their tuners for the GC7 & GC8? They're good looking slothead tuners but I can't find them anywhere?
PostPosted: Sun Feb 28, 2010 10:25 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've built 3 slotheads. Like Hank, I used the open Gotoh's on 2 of them, but the client requested Waverlys on the other. I'm re topping a small Parlor with the 3 on a plate Gotoh's and then seem to work fine. I haven't changed the buttons on any of them. If I need any with special buttons I'm going to beg Burton to let me send him the tuners, and have him make, and change the buttons eek
PostPosted: Sun Feb 28, 2010 3:26 pm
Here's one I made. Inspired by Chris' video I pulled the metal buttons off the Grover sta-tites and put on some ebony knobs from Stewmac. I was a little concerned that the superglue only joint would be weak, but it seems to be holding up fine so far.
BTW, have you considered the "Golden Age Restoration Tuners for Slotted Peghead"? http://www.stewmac.com/shop/Tuners/Guitar,_slotted_peghead_tuners/Golden_Age_Restoration_Tuners_for_Slotted_Peghead.html?tab=Pictures#details
