It is currently Sun Jul 20, 2025 2:12 pm
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jul 03, 2008 12:27 pm
That really is looking great, David.
PostPosted: Thu Jul 03, 2008 7:53 pm
Hi David,
I agree, its looking fantastic. [clap] [clap]
I've been watching this with alot of interest, and I'm I'm kind of excited about it.... bliss .
I hope you post a soundbite!!!
And I'm sure everyone else is thinking the same thing...lol
Aint the OLF a great place!!
cheers,
Claire
PostPosted: Fri Jul 04, 2008 11:36 pm
First name: David
Last Name: LaPlante
Additional progress today:
Fret board installed and fretted.
Preliminary neck carving done.
The pilot Holes for the wooden pegs are drilled, the odd uneven positioning is seen on the original. The neck once had a 7th peg in the center equidistant from the top four.
Here is the heel, I always like to live with the neck shaping for a few days and take another look at it when I'm fresh in order to further refine it. The tall heel with slender profile is seen on the original guitar. One of the fun aspects of this type of project is attempting to capture the character of the original instrument.
The bindings have also been leveled and scraped. In this particular aspect the cardboard has taken away any advantage that it might have had initially (cheap, of even thickness etc.) in that this operation was far more finicky that if done in wood. Because I chose a board with an outer paper layer, no scraping or sanding is possible to assist in leveling the binding with the sides and back. Also the softness of the cardboard makes accurate cutting of the binding channels difficult, also the glue tends to soften and deform them slightly as the bindings go in.........I can perhaps see why Torres only made one of these! However the thing rings like a normal construction when you thump it............
PostPosted: Sat Jul 05, 2008 3:33 pm
Impressive, David! [clap] It looks so life-like. ;)
Carlton Macksam
Muskegon, Michigan
PostPosted: Mon Jul 07, 2008 10:22 am
David,
I hope you write an article for Guitarmaker or Lutherie magazine. This is exactly the sort of thing that they need.
PostPosted: Mon Jul 07, 2008 5:27 pm
First name: Jim
Last Name: Kirby
Mike Mahar wrote:
David,
Yes, second that!
Jim Kirby
kirby@udel.edu
PostPosted: Mon Jul 07, 2008 10:35 pm
First name: David
Last Name: LaPlante
I'm applying egg white to the top and bindings to prevent bleeding once the wash coat of shellac is applied. Since only the top and neck with get a full blown french polish finish (the back and sides will get a very sparingly applied seal coat of shellac) I'll be working them up separately.
I just received my replica pegs today and have given them their preliminary fitting. I produced a drawing of the pegs that Torres typically used from my research and had them made by a luthier and peg maker in the UK. These particular ones are rosewood and unadorned as on the original.
I'm ready to undertake the french polish on the top.
The original of this guitar has a rather dark polish which I will attempt to replicate.
PostPosted: Tue Jul 08, 2008 2:30 am
David, I'm enjoying this a lot. Really an exciting project.
An aside: Have you found that sizing with egg white will prevent color bleeding from a wood such as cocobolo under shellac or nitro lacquer topcoat? Cocobolo, especially, has given me bleed problems, and shellac as a sealer has not helped. Do you use straight egg white, or do you make a glare first?
Thanks!
PostPosted: Tue Jul 08, 2008 6:48 am
Nice looking pegs. Great work on the heel, I like the profile. The whole guitar is fascinating. It looks very light weight with the use of the peghead and cardboard, I'm wondering what the final weight will be. Is it fragile or stronger that you expected?
PostPosted: Tue Jul 08, 2008 8:26 am
First name: David
Last Name: LaPlante
Howard, I'm using the egg white just as it comes from the shell. It works better if you brush it smoothly as opposed to vigorously and whipping it into a froth.
I haven't had any experience in regard to Cocobolo. The worst wood in my experience has been good old East Indian rosewood. The alcohol in the shellac wash coat really makes a mess with this stuff.
The egg white wash coat has solved this problem for me.
Here is a recent guitar where the wash coat nicely prevented any bleed from the Brazilian rosewood inlays into the lighter cypress and spruce.
Marc, according to Grondana and Waldner, the orginal guitar weighs in at 2.55 lbs (1.16 Kg). As I mentioned earlier, I used a bit thicker board than Torres on the back (2.2mm opposed to 1.8mm), and much thicker on the sides (2.2mm opposed to 1mm) than Torres. I also omitted all the additional reinforcement that has been subsequently added to this guitar including two slats that run the length of the back on either side as well as side stays every 3 cm or so. My digital scale wouldn't register the weight of the replica so I'll have to check it elsewhere. It is however much more rugged than I would have anticipated.
PostPosted: Tue Jul 08, 2008 9:11 am
First name: David
Last Name: LaPlante
Monica Esparza describes the egg wash process nicely here:
http://www.monicasguitars.com/Main%20Bo ... ggwash.htm
PostPosted: Tue Jul 08, 2008 9:37 am
I've used egg white or thin HHG for sizing and both can prevent bleeding. But this barrier can be wore easily during the pumice pore-filling process unless the shellac film is thick enough. David, do you have a better way? Luckily the pores of cocobolo aren't big.
PostPosted: Tue Jul 08, 2008 9:42 am
First name: David
Last Name: LaPlante
I also wanted to recommend my peg source.
http://www.brucebrook.co.uk/
He did a really nice job of replicating my specs for the correct type of pegs.
In addition to the plain rosewood ones for the replica, he did a very nice set in ebony of the ones with the little bone domed "caps" so often seen on original Torres instruments. I produced a drawing for these based on my photos the original SE 151A guitar.
PostPosted: Tue Jul 08, 2008 9:45 am
First name: David
Last Name: LaPlante
CW, I'm using the LMI micro bead filler then sanding it back prior to the egg wash application. That way the film remains intact.
PostPosted: Tue Jul 08, 2008 10:52 am
Thanks, David. FYI, here's how to make a glare. I haven't tried it yet, but it's apparently done in order to prevent frothing when painting on the egg white. Glare has been used for many centuries to size paper to limit its adsorption, so that ink will make a sharp line, and not spread.
Glare Recipe
Whip one egg white until stiff peaks form.
Sprinkle approximately 1/3 egg of water over peaks (“1/3 egg of water” means eggshell
of water, that is, the volume of water that would fill, in this case, the smaller half of the
eggshell).
Let stand over night.
Egg whites will become frothy and liquid will separate out; pour this liquid out from
under the froth into a jar. This is the glare. Discard frothy stuff.
Stored in the refrigerator, the glare will last for months. It may discolor and get a little
more yellow or brown. It will also get smelly. So long as the liquid remains clear, it is
fine; the older the better for good consistency. If the liquid gets cloudy or milky, the glare
has spoiled and is breaking down chemically—discard and prepare a new batch.
PostPosted: Tue Jul 08, 2008 11:52 am
Thanks for sharing all this with us, David.
I know the LMI's micro-bead filler is tinted. I was surprised that it's put on before the egg-wash. Do you tape over all your purflings etc. when applying the filler, or just spread it everywhere. I've only ever pumice filled then FP'd so I don't have any experience with this stuff, but I hate working the pumice in and want to try something like the micro-bead or Z-poxy - and not make a mess of things for once.
-Clint
-Clint Beacock
PostPosted: Tue Jul 08, 2008 1:12 pm
First name: David
Last Name: LaPlante
Clint, LMI's Micro bead filler (even the dark "walnut" color that I use) once dry sands off wood purflings nice and cleanly. In the case of the guitar shown above I taped off the cypress and spruce and just filled the purflings but that was done to actually lessen the work since the cypress and spruce did not need to get any filler.I usually sand the guitar to 100 grit, apply filler to the sides and back entirely then resand with 100 and resume up the grits to 180 (or 220).
PostPosted: Tue Jul 08, 2008 5:03 pm
Thanks again David.
I think I'll try that method on my next.
-Clint Beacock
PostPosted: Wed Jul 09, 2008 7:32 am
Thanks David. This is an excellent project!
PostPosted: Thu Jul 10, 2008 11:02 am
First name: David
Last Name: LaPlante
The French polishing is proceeding well.
It is believed that this is Torres' only guitar which originally had a golpeador (tap plate) so here is my replica, in European maple as on the original. I'll attach this last once the bridge is on.
PostPosted: Thu Jul 10, 2008 12:23 pm
Fascinating, David!
Many thanks for posting your progress.
PostPosted: Thu Jul 10, 2008 12:28 pm
Country: Romania
Just a guess/hunch, but I really doubt the golpeador was set by Torres.
The top is getting a nice vintage look! What shellac type are you using?
Build log
PostPosted: Thu Jul 10, 2008 2:10 pm
First name: David
Last Name: LaPlante
Alex, it's the Shellac4 (Amber) from LMI.
As far as the Golpeador the assertion that it's original is made by Grondona and Waldner....it is interesting to note however that Romanillos doesn't mention it in the several books where the guitar is included.
This brings up an interesting point in making replicas of Torres' (or any other maker's) guitars. Should one reproduce the guitar in it's present configuration? Or, should the guitar be made as the maker (as far as it can be determined) originally made it?
If the latter is the case, then most Torres replicas should have wooden pegs in place of the machine heads that have been later added (along with extra wood to thicken the pegheads) to them. La Leona is a good example of this, where a 4mm rosewood plate has been added to the head along with "crude" slots for the tuning machines. Indeed some original Torres guitars have had machines from the beginning (FE 08 and FE 17 are good examples or SE 114). But I would be surprised if those making replicas of the ones that had pegs originally, were making them in that original configuration. Original or no, I will most likely use the tap plate in that it is unique and the guitar is immediately recognizable with it.
My thought process in general in making replicas (SE 114, FE 14 and SE 151A) has been to seek out guitars that first are appealing, would be nice to have as part of my reference collection, but also guitars which I have either seen in person, handled or had excellent information as to their details. Thus I've selected those which met the first criteria, but for which I had enough documentation that I could make a replica that would feel, most importantly to me, credible.
PostPosted: Tue Jul 15, 2008 4:13 pm
First name: David
Last Name: LaPlante
I'm at the point in the polishing where it's best to leave off. The limitations of the cardboard (the more you fool with it the worse it looks...) are such that I think a nice thin polish will look best with the thin sealed cardboard surface.
Here is the bridge getting its polish prior to positioning.
PostPosted: Tue Jul 15, 2008 4:25 pm
Country: Romania
the golden tone of that top is very nice!! I will definitly try egg+darker shellac on my next Euro top. I will soon start finishing a Lutz guitar but it has a pinkish quality to it so i guess a neutral shellac will be better?
Build log
Users browsing this forum: dofthesea, Ken Lewis, Terence Kennedy and 24 guests
