It is currently Fri Aug 01, 2025 11:34 am
 Post subject: 1890 Martin restoration
PostPosted: Sat Mar 23, 2013 6:14 pm
I recently had an old Martin guitar come into the shop for some work. With John Hall's help we were able to determine that this is a model 2 from 1890. It was strung with steel strings which is way to much tension for this little guy. Maybe that is why the left part of the x brace was completely broken in half. Someone has tried to repair it but improperly. With John's help we determined that to do it right the back needed to be removed so that we could get inside the guitar. The bindings, tuner knobs, heel and end caps and rosette rings are ivory. The bridge pins appear to be plastic, , not original. The back and sides are Brazilian rosewood and the top spruce. On a scale of 1 to 10 the pucker factor was a good solid 12 as I removed the back. It took me at least 2 hours to remove it. Care was taken to keep the ivory bindings and the dark/light back purfling veneers intact. Now that the back is off I can get into the restoration of the braces.
PostPosted: Sat Mar 23, 2013 6:15 pm
more pics
PostPosted: Sat Mar 23, 2013 6:40 pm
First name: EddieLee
Last Name: Brown
Good work Robbie. Thanks for the Pictures?
_____________
EddieLee
PostPosted: Sun Mar 24, 2013 6:20 am
First name: Tony
Last Name: Bybee
City: Sulphur Springs
Zip/Postal Code: 75482
very cool! you must have nerves of steel.
PostPosted: Sun Mar 24, 2013 10:52 am
First name: Big
Last Name: Jim
That is excellent work ! Love the pics to , the process is alot easier to comprehend when its can be visualized [:Y:] THANK YOU for helping this subforum get going with this excellent work and Post !! [clap]
PostPosted: Sun Mar 24, 2013 7:26 pm
First name: Hugh
Last Name: Evans
Looks like great work thus far. At least it was just using steel strings and the braces are broken... They could have been "repaired" with a generous slathering of gorilla glue. I look forward to seeing this restoration as it progresses, that guitar looks like it should clean up very nicely.
PostPosted: Mon Mar 25, 2013 12:32 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I hope you're taking lots of measurements. I bet a lot of forum members would love to have plans or at least a tracing for a size 2 (including me!!) I love those old small body guitars
PostPosted: Mon Mar 25, 2013 1:30 pm
First name: Tony
Last Name: C
City: Brooklyn
It looks like the back is in excellent shape from the pics. Does it have any cracks?
Also, it seems like removing the back took a lot of the lining off of the sides. Do you plan to reuse the linings or make new lining?
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Mar 25, 2013 6:14 pm
The back and sides are in great shape. Only a couple of minor cracks in the sides. I will reuse the same kerfing/linings
PostPosted: Mon Mar 25, 2013 7:45 pm
Robbie, I'm enjoying this one. I hope you show in detail how you put the back on, I have to do the same thing to an old Gibson I have in the shop.
PostPosted: Mon Mar 25, 2013 8:20 pm
First name: Tony
Last Name: C
City: Brooklyn
Amazing. Thanks for the reply.
PMoMC
PostPosted: Tue Mar 26, 2013 8:08 am
Looks like a lot of fun. I too would love it if you produced a plan from that. I find it interesting that they use 5 braces for the back and those are beefy ones too!
