The new Schneider/Karol circle cutter http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=8728 |
Author: | Rod True [ Sat Oct 07, 2006 4:57 am ] |
Post subject: | |
Well, I took coach Tony's (as Serge would say) advise and instruction's from circle cutter details topic and built one for myself. It is slick, I just finished it up this morning and it is soooooooo much better than the plywood plate I was using. Thank you, Thank you, Thank you Tony. Here are some pics. ![]() ![]() ![]() I cut a little walnut turn knob for it and cut some little grooves in it as suggested by Dennis E in the original post. Thanks Dennis. ![]() I just love this place. Thanks again for all the great ideas around here everyone. |
Author: | Joe Beaver [ Sat Oct 07, 2006 4:59 am ] |
Post subject: | |
I love that tool ![]() ![]() ![]() It looks professionally done! |
Author: | Serge Poirier [ Sat Oct 07, 2006 5:23 am ] |
Post subject: | |
Very neat Rod, WOW! What Joe said, real pro job! ![]() ![]() ![]() ![]() ![]() |
Author: | Dave Rector [ Sat Oct 07, 2006 5:48 am ] |
Post subject: | |
Nice job Rod! What is the black stuff you used? |
Author: | Roy O [ Sat Oct 07, 2006 6:47 am ] |
Post subject: | |
Very impressive Rod. Looks like I'll have to save this to my "must build" file. |
Author: | Wade Sylvester [ Sat Oct 07, 2006 6:49 am ] |
Post subject: | |
Thanks for the pics Rod! I can clearly see the benefits of such a great tool! |
Author: | D.L.Huskey [ Sat Oct 07, 2006 7:28 am ] |
Post subject: | |
Pretty slick Rod. Someone should put one of these in the "Jigs, Tools and Techniques" section. |
Author: | CarltonM [ Sat Oct 07, 2006 7:29 am ] |
Post subject: | |
Pretty darn cool! Thanks, Rod. And Tony, too. |
Author: | Rod True [ Sat Oct 07, 2006 8:11 am ] |
Post subject: | |
Thanks Guys, Of course nothing is ever perfect the first time out right. Well I went to go and cut a rosette channel with it and looking at the layout on the top, I took a second look at the base and realized that I couldn't cut a small enough soundhole. Well, I had to make a slight modification so here it is. ![]() Now I can cut as small as 2" dia and it increments very well. This is a pic of the test cuts after the modification. 3/16" pin hole and 1/4" cutter bit. ![]() |
Author: | Lillian F-W [ Sat Oct 07, 2006 8:31 am ] |
Post subject: | |
Great job Rod. When I first looked at the pictures I thought it was something you picked up from a vendor somewhere. It is definately going in the must build pile. And I second the notion that you ought to write it up and put it in the jig section. Thanks for sharing. |
Author: | Rod True [ Sat Oct 07, 2006 9:01 am ] |
Post subject: | |
I really must insist that Tony Karol gets the credit for this fine tool, his tool is my inspiration. As he would probably say that Richard Schneider was his inspiration to build his. I do a little bit different than Tony's, which is the way it should be. I used 3/8" stabilizer rods on mine as I felt that 1/4" was to wimpy. I will be happy to have it in the jigs tools & techniques section if Lance and Brock want to put it there. Oh and Dave Rector, the black material is UHWM. Got it from a local plastic tank manufacturer. Total cost to build this is about $5-$8. |
Author: | Serge Poirier [ Sat Oct 07, 2006 9:48 am ] |
Post subject: | |
WOW Rod, the results are there, i agree with everyone who wishes to have this tool in the jigs section, it looks like you just bought it from a store, really neat! ![]() |
Author: | Anthony Z [ Sun Oct 08, 2006 12:08 am ] |
Post subject: | |
Rod -- yours looks excellent. I like the design of yours better than the one I built (looks nicer to). Here's the version I built from an article I found in a Big Red Book. Mine is built to hold the shaft of my Foredom When I posted mine it spurred some debate from the venerable MichaelP as to whether it would work ![]() Let us know how you like yours. |
Author: | TonyKarol [ Sun Oct 08, 2006 12:09 am ] |
Post subject: | |
Hey Rod ... as I was reading down thru the posts, and looking at the pix, the first thing that hit my mind was how small a radius it would do, and you might need to mod the jig, as I had to do to mine for the first 3.5 inch soundhole on a parlour. You nailed it though before I could get this out. Well done. |
Author: | Serge Poirier [ Sun Oct 08, 2006 5:07 am ] |
Post subject: | |
Anthony, neat little jig, do you do your inlays with this set up? |
Author: | Anthony Z [ Sun Oct 08, 2006 7:42 am ] |
Post subject: | |
Serge I have another base for the jig shown above that I use for cutting my inlay pockets. I just remove the top part (which has the wood block on top) and attach it to a small base I have. Works great -- essentially 1 jig - 2 purposes. Happy Thanksgiving Serge |
Author: | Rod True [ Sun Oct 08, 2006 5:25 pm ] |
Post subject: | |
Thanks Captin Tony. Anthony, your's looks like it would work just fine, and I bet it does. I sure love great ideas like this and many others I've found shared by the great group of people here. Thanks to everyone for sharing an idea. Now keep em' coming, I wouldn't want to build a guitar or anything ![]() |
Author: | Serge Poirier [ Sun Oct 08, 2006 5:30 pm ] |
Post subject: | |
Thanks Anthony, really cool, i do have a Dremel foredom(?) and i will have to get it working for me then! Happy Thanksgiving to you and to everyone also! ![]() |
