It is currently Mon Apr 20, 2026 7:56 pm
PostPosted: Sat Sep 09, 2006 7:13 am
Hi everyone
I'm just daydreaming here, thinking about some things I'd like to see with
mahogany. Tortise shell bindings keep coming to mind. Has anyone
worked with it? Or look-a-like plastic binding? How do you bend it?
PostPosted: Sat Sep 09, 2006 7:24 am
James,
It can be bent as it's put on. No need to bend it ahead of time.
PostPosted: Sun Sep 10, 2006 1:34 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Dip it in a little hot water for tight turns and/ or thick binding. Hot
sand works great too if you have any.
Louis
- Louis Freilicher
PostPosted: Sun Sep 10, 2006 11:52 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Gentle curves like a guitar can be bent as you go. If I was using it for a mando scroll or something similar, I'd prebend like Louis described - you can also use a heat gun if you're careful...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Sep 11, 2006 12:12 am
Great tip there Louis and Mark, thanks!
PostPosted: Mon Sep 11, 2006 3:17 am
First name: Louis
City: Belchertown
State: MA
For tight headstocks and scrolls etc. I sometimes make up a little
form out of scrap, tape the bindings to it and heat with a hair dryer
or heat gun set on low. Grizzly makes a nice one that has adjustable
heat control.
Louis
- Louis Freilicher
PostPosted: Mon Sep 11, 2006 3:55 am
[QUOTE=Louis4052] For tight headstocks and scrolls etc. I sometimes make up a little
heat control.
Louis
Becareful though this stuff burns (as in FIRE! not scorching) so fast it nearly explodes.... be careful.
PostPosted: Mon Sep 11, 2006 8:50 am
First name: Louis
City: Belchertown
State: MA
oops!
LouisLouis405238971.9844675926
- Louis Freilicher
PostPosted: Mon Sep 11, 2006 8:51 am
First name: Louis
City: Belchertown
State: MA
Yes Brock is correct, most of the tortoise and Iviroid bindings are
nitrocellulose and can go up in flames fast!! I would stick with hot
water or sand in all but the most extreme cases.
I did use the hairdryer method while replacing bindings on a 1940's
Epiphone archtop. I believe those were white ABS plastic bindings
that may be more heat resistant. (i.e. they will burn and melt fast
but might not explode.)
Do use caution with fire!
Louis
- Louis Freilicher
cron
