| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Nut - High E string problem http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=7899 |
| Author: | GregG [ Mon Aug 07, 2006 12:34 pm ] |
| Post subject: | |
I just can't figure this thing out. I made my nut as usual, seems square, and flat on the bottom, cut my slots with nut files angling deeper toward the tuners, every string sounds great except the high E which when placed on top of the nut next to the slot sounds super, slide it into the nut and thud it loses it's punch, dead as a doornail. I've cut the slot a tad deeper with the next wider file that didn't work. Is it possible the nut is defective in that particular area or am I missing something obvious here? Thanks, Greg |
| Author: | mesquite8 [ Tue Aug 08, 2006 6:52 am ] |
| Post subject: | |
Hi Greg I had something simular happen to me. I don't really think it is the same problem you have because you said you used the next bigger size slot file. In my case I was getting a deadening of the sound plus a strange twang on the E string. It turned out my slot was too narrow and the string was getting pinched and not seating all the way down. I widened the slot a little to allow the string to go all the way down and the problem went away. Dave |
