A shark bit my fingerboard? PICS! http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=5670 |
Author: | peterm [ Wed Mar 15, 2006 4:47 pm ] |
Post subject: | |
Well, it wasn't a shark ![]() A lesson well learned....never take your eyes away from your router ![]() So here's what happened...I was routing my neck flush with the fingerboard, everything went smooth as usual...until I lifted the routed of the fingerboard, looked around to see the floor covered with shavings, when I turned to put the router down and as I moved my arm towards the table...BAM ![]() ![]() So I guess the best thing to do is remove the fingerboard and glue on another one. I was lucky, after all the neck is still intact ![]() Any suggestions for the easiest way to remove the fingerboard? It was glued with titebond yesterday.. Thanks again, |
Author: | Serge Poirier [ Wed Mar 15, 2006 4:52 pm ] |
Post subject: | |
So sorry to hear and see that Peter, i hope someone will come to the rescue quick, at least you did not get hurt, that's the most important thing Good luck with the repair! Serge |
Author: | Brock Poling [ Wed Mar 15, 2006 4:56 pm ] |
Post subject: | |
I put a towel down on a work bench, lay my heat blanket on it, clamp the neck to the blanket (face down of course) an in about 5 minutes you should be able to unclamp it and peel it right up with a putty knife. You may then want to clamp the neck to a known flat surface while it cools. Just put a piece of wax paper down so the glue residue doesn't rebond to the clamping surface. ![]() |
Author: | peterm [ Wed Mar 15, 2006 5:02 pm ] |
Post subject: | |
Thanks Brock....I'll give it a try ![]() |
Author: | Kelby [ Wed Mar 15, 2006 5:11 pm ] |
Post subject: | |
Ouch! Do you find that you save much time routing the neck flush as opposed to using hand tools? A block plane or spokeshave (and a rasp in the heel and peghead area) make pretty quick work of it, but maybe I'm missing out. |
Author: | peterm [ Wed Mar 15, 2006 5:15 pm ] |
Post subject: | |
Kelby, I only use the router to trim the neck flush with the fingerboard....after that I use only hand tools and a belt sander... Goes to show you, it only takes a sec ![]() |
Author: | peterm [ Wed Mar 15, 2006 5:32 pm ] |
Post subject: | |
This is why the OLF is the best place on the web! ![]() Thanks to Brock's advise I had the fingerboard off the neck and the eck cleaned in less than 10 mins! and to think I was going to use a clothes iron? ![]() Thanks again... |
Author: | A Peebels [ Wed Mar 15, 2006 11:55 pm ] |
Post subject: | |
I used to have s shoe that looked sort of like that. I was standing on a board when the router got loose almost 30 yr ago. I learned a lot about respecting routers that day. Al |
Author: | Bruce Dickey [ Thu Mar 16, 2006 3:32 am ] |
Post subject: | |
How about a shark inlay? I know you probably have plans for the neck that didn't include one. I bet an inlay artist could fix it up. |
Author: | clavin [ Thu Mar 16, 2006 4:40 am ] |
Post subject: | |
shark related inlay. Just my speed.... ![]() (of course others are equally speedy here as well.... Remember the Grit code!! ) ![]() Craig L |
Author: | Don Williams [ Thu Mar 16, 2006 4:57 am ] |
Post subject: | |
Peter, my heart goes out to you man... that kind of thing really hurts. On the bright side, at least it was now and not later on in the process. A hard lesson, but you won't repeat it. Brock's suggestion is great for removing it. I can see I'm not the only one who has had to remove one... |
Author: | hoosierukes [ Thu Mar 16, 2006 4:57 am ] |
Post subject: | |
Norman Takeya's Shark Bite Uke ![]() ![]() ![]() ![]() From the Ukulele Guild of Hawaii Site |
Author: | Serge Poirier [ Thu Mar 16, 2006 5:46 am ] |
Post subject: | |
Ever cool! ![]() |
Author: | hoosierukes [ Thu Mar 16, 2006 6:21 am ] |
Post subject: | |
The shark bite uke was the first to sell at the 2004 UGH Convention. |
Author: | CarltonM [ Thu Mar 16, 2006 7:29 am ] |
Post subject: | |
Peter, there's always a bright side...you could have been flush-trimming the top! ![]() ![]() |
Author: | Brock Poling [ Thu Mar 16, 2006 8:18 am ] |
Post subject: | |
[QUOTE=Don Williams] Brock's suggestion is great for removing it. I can see I'm not the only one who has had to remove one... [/QUOTE] Yep... sometimes it is one step forward, two steps back. That is also the lesson that taught me to use tightbond II for bindings as well. ![]() |
Author: | crich [ Thu Mar 16, 2006 3:24 pm ] |
Post subject: | |
Brock, Please explain why you use Titebond II instead of the "Orginal" on bindings as well? Do you use TBII on the fretboard also? Clinton |
Author: | Brock Poling [ Thu Mar 16, 2006 5:05 pm ] |
Post subject: | |
I use either original titebond or LMI white to put the fingerboard on the neck...(although I have been thinking about giving epoxy a try). Using titebond II on fingerboard bindings helps because if you have to remove the fretboard they don't delaminate as easily. If you use the same glue for everything once you get enough heat to remove the fretboard from the neck it is usually enough heat to release the bindings from the fingerboard.... ask me how I know... ![]() |
