It is currently Mon Apr 20, 2026 3:38 pm
PostPosted: Fri Feb 24, 2006 4:32 am
Gentlemen, (and ladies, to be gender-inclusive, but I haven't seen any posters from the fair sex here as yet),
I was at a friend's house this past weekend, and played his Tippin OM briefly. One of several things that struck me is that there is so little difference in tone whether a string is played open or fretted. Also, when going up the neck, there was far less "thumpiness" than I'm accustomed to. Tone and sustain varied little. That is, playing an A on the low E 5th fret sounded very much like an A on the open A string. It was the same going higher up the neck.
There were a host of other fine aspects to this guitar, but I'm very curious about these. Could it have been Neck stiffness? Strings? Neck resonance? Bracing? All of the above? Any comments?
PostPosted: Fri Feb 24, 2006 4:40 am
Was there a zero fret?
Evan
PostPosted: Fri Feb 24, 2006 10:10 am
Nope, no zero fret.
PostPosted: Fri Feb 24, 2006 10:24 am
It's called "quality". Tippin makes great guitars, and you will find as you build more yourself (do you build?) that you will tend to get guitars that are well-balanced all the way up the fretboard. Part of it is having a well designed neck, yes, but also the workmanship that goes into the top and the bracing etc.
