It is currently Mon Jul 21, 2025 1:35 am
PostPosted: Fri Feb 10, 2006 9:56 am
hi!
i'm building a solid body neck-thru bass and i dont know what finish to put on..
i want a very high gloss durable clear finish...what do you propose!!..laquer?? poly-heretane??...HELP!!
thanx
PostPosted: Fri Feb 10, 2006 10:19 am
It all depends on the gear you have available, and on your experience with a
spray gun, or brush and various finishes (mixing etc.).
Without a compressor and spray gun, or other system, there are nitro spray
cans available that would give you a very good result:
ReRanch
StewMac sells nitro spray cans as well but not as good IMHO.
Robbie O'Brien has an excellent DVD on guitar finishing where he covers
most of the available finishes:
DVDs
Keep in mind that most solvent-based finishes are highly toxic, flamable
and dangerous to use, even in a ventilated area.laurent38758.7650810185
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Feb 10, 2006 10:28 am
Hi Patrick, welcome here, depending on your experience, i'll second Laurent with Robbie's DVD, seems to be really appreciated here. just my 0.02 cents!
PostPosted: Fri Feb 10, 2006 11:43 am
hi!
as for equipment i use a HVLP gun with a HUSKY 80 gal compressor..i spayed alot of metal/wood pieces in the past...but it's my first time with a musical instrument.
So i'm not quit sure what to use : laquer (looks really good , but not as resistant as poly-urethane)...poly : well..tought as hell... but is it the only choice????
I really want the look of "liquid glass" ...
sorry for the next question : what the hell is NITRO??
PostPosted: Fri Feb 10, 2006 11:55 am
Nitro Celulose Lacquer, It is used extensively on Guitars, but is pretty nasty to use, both highly flammable and toxic.
PostPosted: Fri Feb 10, 2006 1:15 pm
If durability is a high priority, it would seem that the choice is between polyurethane and polyester. You could go with a two-part polyurethane.
Todd Rose
Ithaca, NY
PostPosted: Sat Feb 11, 2006 11:54 am
I would recommend a water base KTM-9 if you don't have the proper tools a spray booth to use nitro. Mike Doolin has a good set of instruction here at the OLF...and his guitars look great!
PostPosted: Sun Feb 12, 2006 9:31 am
I spray nitro outdoors with an automotive door jamb gun. The weather can sometimes be a problem. Especially this time of year- Its snowing right now, and 29 degrees.
