Another Bracing Query http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=4608 |
Author: | Josh H [ Wed Jan 18, 2006 2:08 pm ] |
Post subject: | |
Your workmanship looks clean to me! I think you have enough strength. I'm not an expert by any means but I really like the look of your design. I'd say it looks comparable to mine in strength. I'm just guessing as I don't know all your measurements. Out of curiosity did you happen to weigh your top. I know a few guys have posted the weight of their tops and I am always interested to see how they compare. What radius are you using on your top? Josh |
Author: | LarryH [ Wed Jan 18, 2006 2:15 pm ] |
Post subject: | |
[QUOTE=Josh H] Your workmanship looks clean to me! I think you have enough strength. I'm not an expert by any means but I really like the look of your design. I'd say it looks comparable to mine in strength. I'm just guessing as I don't know all your measurements. Out of curiosity did you happen to weigh your top. I know a few guys have posted the weight of their tops and I am always interested to see how they compare. Josh[/QUOTE] Thanks for the reply Josh and to answer your last question, no, I didn't weigh the top as it wouldn't mean anything to me at this stage, I'll consider it next time if it will help others make design decisions. My biggest concern was with the tone bars which normally run diagonally across the lower bout. There is MUCH less wood in the two new radial braces but it seems their new position would pick up more stress directly from behind the bridge which I assume is where most of the stress is. I thought about a reinforcing diamond or two across the top joint as those tone bars do nothing now to keep that joint together, what do you think? Thanks Larry |
Author: | KiwiCraig [ Wed Jan 18, 2006 2:26 pm ] |
Post subject: | |
Hi Larry, Gee ! I hope I'm one of those first finished posters ! IMO your braces look plenty strong enough . You even used the A frame set up ! Looks to be very neat and clean work Larry. Very well done. Maybe others may disagree , but I'd say go with your instincts on your bracing plan. There are hundreds of variations out there , what's to say yours isn't the best ever built .I've got a feeling your going to have a very special instrument.. Kind regards, KiwiCraig |
Author: | Serge Poirier [ Wed Jan 18, 2006 2:37 pm ] |
Post subject: | |
Same as Kiwi and everyone, looks stong enough well shaped. If you have a good feeling, go with it no matter what, we're here to learn so don't even be afraid of mistakes because they are also part of LEARNING! My 0.02 cents but there's a bunch of people that are in line to answer you on that, just wait and read ![]() Serge |
Author: | Grant Goltz [ Wed Jan 18, 2006 3:06 pm ] |
Post subject: | |
Larry, Not to worry, go with it. In some respects, this has similarities to what I do. I did a post a week or two ago (lost track of exactly when) on my bracing pattern. You can probably search somehow and find it. I probably would stick a diamond or two over the top joint below the bridge. That is what I do where there is the longest unsupported space. I also brace the upper end sort of like what you have done, but it is to accomodate my adjustable neck angle system. I will be posting more on this in a couple of weeks when I get my next build going. (After a week or so trip to the northern part of Manitoba - no, not a vaction ![]() Grant Goltz |
Author: | LarryH [ Wed Jan 18, 2006 3:21 pm ] |
Post subject: | |
[QUOTE=KiwiCraig] Hi Larry, Gee ! I hope I'm one of those first finished posters ![/QUOTE] Thanks for the reply Craig and YES you are one of those first time builders I was referring to. Seriously considering some kind of ban or maybe a review board that when someone posts such a beautiful first time instrument they are required to title the post "20th guitar". Very nice work again. larry |
Author: | LarryH [ Wed Jan 18, 2006 3:25 pm ] |
Post subject: | |
[QUOTE=Grant Goltz] I probably would stick a diamond or two over the top joint below the bridge. Grant Goltz[/QUOTE] Thanks Grant - still considering some kind of small, shaped cross-grain brace across the top joint I'll post something if I go with it. Any other ideas? Larry |
Author: | Grant Goltz [ Wed Jan 18, 2006 3:40 pm ] |
Post subject: | |
[QUOTE=LarryH] Any other ideas? Larry[/QUOTE] Get on with it so we can listen ![]() Grant |
Author: | Dave White [ Wed Jan 18, 2006 6:43 pm ] |
Post subject: | |
Larry, Dare to be different ![]() ![]() ![]() ![]() The fan braces behind the bridge are, if I have interepreted his posts on the AG Forum correctly, what Rick Turner is currently doing on his acoustic guitars so you are in good company there. I have contemplated doing this on one of my guitars rather than the broken X I currently use. One thing I might have done would be to put a brace behind the bridge plate that joins at the 2 legs of the X braces - I think I've seen it refered to here or elsewhere as the "Musser brace". This doesn't have to be very tall but might help give extra strength for the behind bridge area, as well as the tonal reasons (I think it helps string balance but as usually I could be totally off beam). Your workmanship looks fine and the shaping looks really good. I always was worried about my bracing being not strong enough on my early guitars, but the more I build the lighter I go and yours look great. I'll bet that top really does ring out!! Let us know how it turns out. |
Author: | tippie53 [ Wed Jan 18, 2006 10:04 pm ] |
Post subject: | |
I see you are using the A frame X hybrid. I like the strength of the upper support though I feel there is more that than needed. remember that martin is designed for warrantee issues. What we think isn't what matters , it is what you hear. That is why we all build , as we are looking for the quest of the perfect guitar. As you go you will learn to quantify your placement and get more precise as to placement. Just using intuition isn't the best as you need to know where and why. You are in the ball bark of position. Start charting your tops . That is what I did in my early days so I could find what happens when things get moved around. Keep us posted as I am sure there are some of us with alot of interest in bracing. The parabolic braces are a nice modern touch. john hall |
Author: | Colin S [ Wed Jan 18, 2006 10:20 pm ] |
Post subject: | |
Looks plenty strong enough to me, I think we all build our braces far too heavy as it is. The brace shape looks nice and smooth to me which is what I aim for. I like the idea of the fan braces behind the bridge (I'd would've used three), harks back to the days of the 18th century lutes and many of them are still holding up fine, in fact I restored one a while ago. I like to see people ploughing their own furrow, if we don't innovate we stagnate. You get my vote. Colin |
Author: | LarryH [ Thu Jan 19, 2006 3:03 am ] |
Post subject: | |
Thanks so much for taking the time to post your thoughts and ideas and the encouragement. I'll probably go with my feelings again about strength and added brace positions, perhaps a small brace behind the X brace and in front of the bridge plate, and a small, smooth-shaped reinforcing brace across the top joint. thanks again Larry |
Author: | John How [ Thu Jan 19, 2006 3:13 am ] |
Post subject: | |
You know I think it's prbably going to sound like a guitar so I say go for it. |
