12 string guitar bulding http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=4579 |
Author: | Andy Zimmerman [ Tue Jan 17, 2006 4:55 am ] |
Post subject: | |
Hi I am considering building a 12 string guitar. My music teach has been wanting one for a long time and I thought I might suprise her by making one for her. I have a Scott Antes 12 string drednaught plan set. I am probably not going to use a dreadnaught body size, but either an OM or SJ. Any tricks or words of advice in building/bracing etc? Thicker top plate??? Thicker bridge plate??? Thanks again Andy |
Author: | Pwoolson [ Tue Jan 17, 2006 6:01 am ] |
Post subject: | |
Here's what I've done: don't go any thicker on the top, bridge, or bridge plate. Make the braces slightly taller (maybe 1/16") and that's all you need. The bridge will be bigger in order to fit all of the pins on there. Resist the temptation to make the neck more bulky too. If you laminate a neck and use carbon rods, you'll be fine with keeping it the same depth as a six string. Of course your width will change. If you are making a cutaway, make sure your neckblock is the width of your new 12 string neck and not a six string neck. Don't ask me how I know that one. Arrrrrrg. |
Author: | Rod True [ Tue Jan 17, 2006 6:18 am ] |
Post subject: | |
Any one have any dimensions for the nut and bridge pin width on a 12 string. That's the one thing that has me thinking. |
Author: | tippie53 [ Tue Jan 17, 2006 8:48 am ] |
Post subject: | |
12 strings are not the big a deal , the biggest change is on the bridge and plate. The spacing is still based on the 1 3/4 2 1/4 taper with the 2nd set of strings offset about 1/16 so figure that into the neck. |
Author: | JBreault [ Tue Jan 17, 2006 8:54 am ] |
Post subject: | |
What about all those 12 strings with thier tops bellied in? With Bruce's science project, it seems like a lot of extra force on the neck and bridge with those extra strings. Just curious. |
Author: | Pwoolson [ Tue Jan 17, 2006 9:08 am ] |
Post subject: | |
John, I think 1 3/4 will be pretty crowded with all 12 strings. I've gone 1 7/8 and been very happy with the playability. |
Author: | Sylvan [ Tue Jan 17, 2006 9:23 am ] |
Post subject: | |
When I build 12 strings I make three structural changes to the bracing of the top. 1) the cross brace behind the soundhole needs to be beefier- I go from 1/2" to 9/16", 2) if you are using a conventional "x" brace design I add a 3rd tone bar coming off the "x" brace, and 3) I increase the size of the bridge plate 1/2" over my 6 string design. I also do not scallop the top braces. I learned these changes from Bozo Padudavac, who, in my opinion, has always made the best sounding 12 strings. I also find these changes eliminate the tops bellying. I make no changes to the back bracing. I make the neck in the same way as a 6 string but the freboard is wider 1 7/8" - 2 5/16". Therefore the fingerboard taper is slightly different than my 6 strings. I hope this helps! |
Author: | Andy Zimmerman [ Tue Jan 17, 2006 9:52 am ] |
Post subject: | |
Thanks Andy |
Author: | Rod True [ Tue Jan 17, 2006 10:23 am ] |
Post subject: | |
Thanks also. |
