It is currently Wed Sep 17, 2025 6:48 am
PostPosted: Fri Dec 16, 2005 4:22 pm
I regularly have gotten a message saying that there is a problem with the
size of the field when I try to edit. When this happens, no amount of change
to the edit ever helps. What's up with that?
PostPosted: Fri Dec 16, 2005 5:53 pm
Howard...I can't help with the edit function...but your posts are usually so well composed and articulate...I'm surprised you'd even need the edit function!!!
PostPosted: Fri Dec 16, 2005 8:28 pm
Howard it is usually that the system has added too many re's in the subject line edit the subject line and it should be ok
PostPosted: Sat Dec 17, 2005 12:16 am
What Russell said.....
When you are struggling try changing the subject line.
Also, if you are having specific problems PM me when you are having them and perhaps I can duplicate the problem. Once I can duplicate it that will help us pin point where to fix it.
:_)
