Spraying Shellac http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=3297 |
Author: | RussellR [ Thu Sep 22, 2005 7:47 am ] |
Post subject: | |
Hi all I have been having a few lessons from a local furniture maker trying to get my finishing really up to Standard. He showed me a technique where he sprays the Shellac, he uses a pre mixed product, but I checked and it is not dewaxed. I usually make up my own from flakes, but was not sure on the cut I should be using for spraying. Any one got an idea ? Many Thanks Russell |
Author: | Michael Dale Payne [ Thu Sep 22, 2005 8:00 am ] |
Post subject: | |
If you want a premixed 100% wax free buy Zinsser's Bull's Eye Seal Coat. Be Sure to get The Seal Coat and not the Sanding Sealer. The Seal Coat is 100% wax free pure shellac 3# cut, the Sanding Sealer is not. You would not have any issues using your own cut shellac in a sprayer. I would screen it, but I screen any thing I spray. |
Author: | arvey [ Thu Sep 22, 2005 8:06 am ] |
Post subject: | |
If you already are mixing your own why not use that. I think the question is what cut to use for spraying which I can't answer for you unfortunately. |
Author: | Michael Dale Payne [ Thu Sep 22, 2005 8:15 am ] |
Post subject: | |
IMO 2# is a good cut for spraying as a finish film. I use a 1.5# cut when I seal prior to spraying nitro or KTM9 |
Author: | John Kinnaird [ Thu Sep 22, 2005 8:27 am ] |
Post subject: | |
I wonder why more people don't spray shellac. One of the hazards of wiping on a first coat is the real possibility of pulling color from one part of the guitar to another. White prufling lines can get darkened, tops can get a slight smear from wood dyes in the darker woods. If you spray lightly you can seal all that stuff in place. |
Author: | Michael Dale Payne [ Thu Sep 22, 2005 8:31 am ] |
Post subject: | |
John I think it is be cause the flash off time is so short if you leave you gun for an hour it is gummed up a bit. To me it has never been an issue. I clean right after evey use. |
Author: | Don Williams [ Thu Sep 22, 2005 9:03 am ] |
Post subject: | |
I've sprayed shellac very successfully in the respect that it kept color from bleeding from cocobolo to maple purflings. Unfortunately, I sprayed ktm9 over that, and had some serious adhesion issues. You have to sand back the shellac to around 1200 grit or so wet-sand so that the ktm9 will get a chemical bond with the shellac. |
Author: | Brad Goodman [ Thu Sep 22, 2005 9:48 am ] |
Post subject: | |
Don, Dont you mean mechanical bond? |
Author: | RussellR [ Thu Sep 22, 2005 11:15 am ] |
Post subject: | |
When this guy was demonstarting to me, he applied two light coats over a period of about 30-40 Minutes and then flushed out the gun. The only concern I had was how flammable is the vapour ? I have extraction but it is not up to flammable standards, so I was wondering if I need to change this ? |
Author: | Don Williams [ Thu Sep 22, 2005 11:41 am ] |
Post subject: | |
Oops....yes Brad, I meant mechanical bond. Sorry, brain skipped the groove. |
Author: | Brad Goodman [ Thu Sep 22, 2005 12:29 pm ] |
Post subject: | |
Don, My brain skips whole sides!! |
Author: | BlueSpirit [ Thu Sep 22, 2005 1:03 pm ] |
Post subject: | |
Michael, What do you mean when you say you "screen" anything you spray? |
Author: | Dave-SKG [ Thu Sep 22, 2005 5:41 pm ] |
Post subject: | |
[QUOTE=MichaelP] John I think it is be cause the flash off time is so short if you leave you gun for an hour it is gummed up a bit. To me it has never been an issue. I clean right after evey use.[/QUOTE] Michael are you spraying with HVLP or high Pressure? Also please give a detail of how you clean your gun after spraying Shellac. TIA |
Author: | Bobc [ Thu Sep 22, 2005 9:28 pm ] |
Post subject: | |
Isn't anyone using Target Coatings waterborne shellac? Great stuff, dewaxed, sprays great, soap and water cleanup. |
Author: | Michael Dale Payne [ Fri Sep 23, 2005 12:04 am ] |
Post subject: | |
Hp touch-up gun. Clean-up spray 3 oz pure DA @ 30psi remove needel,nozzel and spring: soak in Da for 10 min Reassembel |
Author: | Michael Dale Payne [ Fri Sep 23, 2005 12:07 am ] |
Post subject: | |
I guess strain is a better term, to remove any undisolved particals |
Author: | Howard Klepper [ Fri Sep 23, 2005 2:41 am ] |
Post subject: | |
I spray shellac at about a 1-1/2# cut. There is no cleanup problem if you shoot some alcohol through the gun right afterward. For good measure I dip the nozzle in lacquer thinner and then blow it out, but that's probably overkill. I either mix from flake or use the light blonde dewaxed stuff made with anhydrous alcohol from Shellac.com. The question about the waterborne is what the added borax does to the longevity of the film. I don't want to wait 10 years to find out it degrades. |
