It is currently Sun Jul 27, 2025 6:23 pm
PostPosted: Tue Jun 14, 2005 3:13 am
Hi Folks,
What are my choices for Glue to set fret position markers ?
Can I buy it from most hardware stores?
Walter
PostPosted: Tue Jun 14, 2005 3:20 am
like the pearl/abalone dots? Thin super glue works good for them. You
can get that anywhere...almost
PostPosted: Tue Jun 14, 2005 4:27 am
I second the superglue. Used to get stewmac's, but any will do, really.
PostPosted: Tue Jun 14, 2005 4:42 am
I use the superglue as well. Just put the dot in the hole, wick some superglue in around it, any you be done.
PostPosted: Tue Jun 14, 2005 5:07 am
I also use super glue, the very thin stuff, BUT you can also use plain elmers glue or wood glue works fine too.
PostPosted: Tue Jun 14, 2005 7:17 am
    I use duco or super glue on plastic and elmers on pearl. Depends what is closer to my hand at the time
john hall
PostPosted: Tue Jun 14, 2005 11:57 pm
State: ON
Super glue.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Jun 16, 2005 2:25 am
Here's my method when I install plastic styrene rod type markers:
Get an empty pop (or soda can depending from which part of the country you hail from), rinse it out and invert the can on your bench so the bottom [dish side] is facing up. Put a drop of CA on the can bottom and dip your fret marker rod into the glue. Insert the rod into the [pre drilled] hole and cut it off with side cuts. Repeat until you are done. Spritz with accelerator or let CA dry on its own. Level dot stubs with a file and sand smooth.
tim...
