It is currently Sun Aug 03, 2025 4:51 am
PostPosted: Thu Dec 13, 2007 10:04 pm
Country: Romania
Sorry for the newb question
I'm doing a madRose bridge and the grain is wild as you can see...
This is quite different from the nicely quartered wide grained Indian RW I used before...
The wood feels solid and stiff, (but on the heavy side)
Thanks!
Build log
PostPosted: Thu Dec 13, 2007 11:30 pm
Alex buddy MadRose would make an excellent bridge.  I can't tell from the photos of yours if there is anything specific to your pieces that might not be acceptable for a bridge.
PostPosted: Thu Dec 13, 2007 11:33 pm
Country: Romania
one nasty thing is that it is oily, or at least that is what i believe judging from the severely clogged sandpaper.
Doing a mock fish-glue-up between spruce and the blank offcuts.
Other than that, with a bit of 360 grit and shellac it looks nothing short of stunning.  Not-making-justice-pic:
Build log
PostPosted: Fri Dec 14, 2007 12:19 am
The chocolate lighter brown Maddy is usually much lighter in weight than EIR. The dark purple-ish red Maddy is a bit heavier than EIR. Either make excellent bridges.
tim...
PostPosted: Fri Dec 14, 2007 12:58 am
First name: Tom
Last Name: Rein
City: Saline
[QUOTE=AlexM] one nasty thing is that it is oily, or at least that is what i believe judging from the severely clogged sandpaper. [/QUOTE]
Ditto that. I would be leery of it due to the high oil content and taking a risk with good adhesion.
Stay with the happy people.
--Reynolds Large
PostPosted: Fri Dec 14, 2007 1:50 am
The only two bridge wood I use are BRW and Mad Rose, I have always found that it makes great bridges adhesion with either fish glue or HHG never a problem.
Here's a recent one on my last guitar.
PostPosted: Fri Dec 14, 2007 1:56 am
I have used mad-rose several times for nylon string bridges... works great !!
Mark
PostPosted: Fri Dec 14, 2007 3:32 am
I use it all the time and never had a problem with adhesion. It is perjaps my favorite bridge material besides BRW of course.
PostPosted: Fri Dec 14, 2007 3:35 am
I love it as well. Never had any adhesion problems. Because I don't use BRW, it's my favorite bridge material.
PostPosted: Fri Dec 14, 2007 4:04 am
Country: Romania
I admit i chickened out after the first mad-bridge I made split while doing the simple task of inserting the saddle. I barely levered it while checking the cut is ok... it would not have survived a single string up to pitch. My luck is that I made the front narrower than usual, otherwise i would have glued it and got the split while stringing....
On the second, pictured, I made the front on the wide side (7mm at base, 5 at the theoretical breaking point) and it feels ok.
Build log
PostPosted: Fri Dec 14, 2007 4:31 am
Country: Romania
LV fish Glue test went nicely:
surface prep: scraped with a razor
clamp time: less than 1 hour
pressure: very low
With the recommended 12h clamping and normal pressure it shoudl hold quite nicely.
Notice how the spruce gave up between grain, but the dark lines ripped some small RW particles.
Build log
PostPosted: Fri Dec 14, 2007 7:00 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use it allot!!!!
I have more than I'll ever need!
it's oily alright-but I've never had a problem with that!
make sure your glue joint is perfect-on the top of the guitar as well as the bridge!!!
Mikewww.collinsguitars.com
Mike Collins
PostPosted: Fri Dec 14, 2007 8:47 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have found that wiping with acetone or even denatured alcohol before sanding or gluing make the task a little easier on oily woods. Sandpaper clogs less.
