It is currently Wed May 13, 2026 7:23 pm
PostPosted: Mon Sep 10, 2007 2:11 am
The only way I could get to .020, was to thickness sand the thicker stuff down to that.  It works fine then.  I have never tried dying it myself though.  Constantines has dyed veneer that isn't bad, but you have to sand it down too.
PostPosted: Mon Sep 10, 2007 2:12 am
PostPosted: Mon Sep 10, 2007 2:13 am
Stupid Jacket!
PostPosted: Mon Sep 10, 2007 2:16 am
Searching the Internet, I see a lot of 1/42" veneer, which is 0.024 ".
PostPosted: Mon Sep 10, 2007 2:24 am
Did you try the off white fiber from BobC? In general, fiber does not take dye well so it is either use the off white or sand or plane down the 1/42 veneer to .020 .
1/42 veneer is around ~.024" so it doesnt take much to scrape it down to .020. In the GAL red books there was a plan on how to build a scraper to thickness the veneer. It is basically a fixed block and a plane blade which is set to the gap needed for thickness.
PostPosted: Mon Sep 10, 2007 2:37 am
StewMac sells .020 colored maple in red, green, blue and black
PostPosted: Mon Sep 10, 2007 2:44 am
LMI sells .002 red, green, blue and yellow in varying widths but they use sycamore I believe.
.020 not .002
PostPosted: Mon Sep 10, 2007 2:52 am
First name: Josh
Last Name: French
City: Houston
here's the scraper jig I use (I don't make pretty jigs). Easy to make, will scrap down veneers well, works perfect for herringbone, etc.
Instagram: @jfrenchluthier
Man those lines are tight.
PostPosted: Mon Sep 10, 2007 2:54 am
Joshua, is that a plane iron?  Does it have a hook, or just sharp.  What's the angle, if you don't mind?  That sounds greedy doesn't it?
PostPosted: Mon Sep 10, 2007 3:48 am
First name: Josh
Last Name: French
City: Houston
Waddy - its an iron from my block plane (I replaced the block plane iron with a Hock iron). The angle isn't very important... veer off 90 a bit on the jig and it seems to give a less agressive cut and a nicer finish.
For the blade I just sharpen the bevel to 600 grit and don't lap the back. Makes for a kind of "hook" that works really well.
PostPosted: Mon Sep 10, 2007 3:54 am
First name: Josh
Last Name: French
City: Houston
That jig is very similar to Eugene Clark's - thats where I got the idea for it. He uses a particular type of plane to micro adjust though, which I think is better (yeah but this jig was free to make!).
PostPosted: Mon Sep 10, 2007 3:59 am
I have .020 Maple in 6 by 36 inch sheets. Let me know if I can help you out!
PostPosted: Mon Sep 10, 2007 5:06 am
Joshua, thanks for that.  Next up on my jig making process.  I even have an extra block plane iron.
PostPosted: Mon Sep 10, 2007 5:34 am
While we're on the subject of veneer.....does anyone have a good source for 1mm veneer?
It seems as though everything is around .6mm or so these days.....I recall buying the standard stuff from Constantine's years ago and it was all .9 or 1 mm as a standard.
PostPosted: Mon Sep 10, 2007 6:07 am
First name: Josh
Last Name: French
City: Houston
David, Constantine's has some veneers at 1/16th of an inch - a little thicker than you asked for though. I'd be interested in other sources as well.
PostPosted: Mon Sep 10, 2007 6:08 pm
Joshua, What type of veneer are you looking for. www.certainlwood.com has some 1/16 inch in poplar, spruce, maple and a couple others. It is hard to find in the exotics since it is considered a waste of good wood.
PostPosted: Mon Sep 10, 2007 6:09 pm
make that www.certainlywood.com
