http://www.luthiersforum.com/forum/
Humidifier - Dehumidifier Combo
http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=13543
Author:  peterm [ Thu Sep 06, 2007 3:54 pm ]
A while ago I posted a thread asking about some of the automatic Humidifier - Dehumidifier Combos available out there for a small shop. I remember the Danby 3 in 1 was one of the recommended models....
Anyone else is aware of any other models?
Author:  Blain [ Thu Sep 06, 2007 4:12 pm ]
Hey Peter.
Not sure if this is what you're looking for, but this says it's both so it might be an option for you as well.
I'll look a little more and let you know if I run across anything else.
Humidifier Dehumidifier
Author:  Blain [ Thu Sep 06, 2007 4:22 pm ]
A decent price on the Danby....
Danby
Author:  peterm [ Thu Sep 06, 2007 4:28 pm ]
Thanks Blain...
I think the Danby may be the best bet!
Author:  Blain [ Thu Sep 06, 2007 4:30 pm ]
You're probably right.
And it doesn't look like there's a whole lot of options out there either. At least not from what I've seen.
Author:  WaddyThomson [ Fri Sep 07, 2007 2:05 am ]
Yeah, that top one is a table-top type unit.   Seems pretty small.
The only thing about the Danby that bothered me was the small dehumidifier tank.  Only holds 6 liters.  For a 60 pint dehumidifier, thats emptying  nearly 5 times a day if the humidity is high.  I couldn't find out whether it had an option of draining directly.  I know you can buy little pumps to pump the water out if you want to.  A lot would depend on how much humidifying and dehumidifying you have to do.  I know I run my AC full out, and still have to run the dehumidifier to keep the shop in the 45 - 50 range.  It's sort of like beating a dead horse.  The dehumidifier raises the temp about 8* and the AC lowers it a little more, but if it's 90+ outside, it's a nice dry 80 - 85 in the shop.
Author:  Michael Dale Payne [ Fri Sep 07, 2007 3:15 am ]
Would not take much to to add a small bulkhead fitting to the tank and pipe it out some where
Author:  EnFuego [ Fri Sep 07, 2007 5:29 am ]
I have just started looking at humidifiers and dehumidifiers for the shop i
am setting up. I didn't even realize they sold the all-in-one units. Thanks
for the heads-up on these.
