It is currently Mon Apr 20, 2026 4:01 pm
PostPosted: Sat Aug 11, 2007 6:20 am
Hi all! Does any body know what to use to remove the l glue left behind after removing a pick gaurd?
I'm trying not to destroy my lac. top. I had a brain fart while installing it(hate it when that happens) Thanks
PostPosted: Sat Aug 11, 2007 6:52 am
You didn't say what kind of guitar, what kind of pickguard, or what kind of glue.   How about some helpful info here...
If it's a contact adhesive then try xylene (Goof Off). If it's a white glue, then get De Glue Goo. You could also try mineral spirits.
None of the above hurt nitro lacquer in short exposures...15 minutes or so.
PostPosted: Sat Aug 11, 2007 7:05 am
Sorry for the lack of info LMI self adhesive pick guard
PostPosted: Sat Aug 11, 2007 9:02 am
First try mineral spirits, and if that doesn't get it, go for the xylene.   Either way, do it in a well ventilated space.   Use and old clean T-shirt and wear rubber gloves.
PostPosted: Sun Aug 12, 2007 9:49 am
Thanks Rick the goo-gone worked like a champ
PostPosted: Sun Aug 12, 2007 10:36 am
naptha/lighter fluid works well for these applications too...
