http://www.luthiersforum.com/forum/
Australian Tonewoods Minneritchi
http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=12970
Author:  Aust Tonewoods [ Wed Jul 25, 2007 9:56 pm ]
Minneritchi Desert Hardwood Back & Side set update
Just an update for you guys who might have a yearning for desert hardwoods. I have received and processed a log which produced relativcely wide Minneritchi sets with curl and birdseye figure. It is similar to Mulga but usually darker and frequently figured. The sets I was able to reclaim will just make the dreadnought profile. As they are partially dried I will need to rack them out for a while before they are available for shipping.
The density and stability of these sets is quite extraordinary. They are about 1100 - 1300kg per cubic metre and shrink only 1 -2 percent.
I haven't posted these set anywhere else so if you have any interest send me a PM. I will have 3 or 4 sets for sale.
regards
Tim
Full set
Backset up close
Birdseye and curl figure on backset
Side figure with incredibly fine curl/fiddleback
Author:  KiwiCraig [ Wed Jul 25, 2007 10:39 pm ]
Uncle Tim ,that looks remarkable wood. 1300 kg. Wooaa !
In fact , all your wood is extroadinary . I'm frightened to visit your site nowadays
Great find Tim.
Cheers Craig
Author:  Aust Tonewoods [ Thu Jul 26, 2007 2:40 am ]
Limited offer
If any one wants to put in a forward order for one of these sets the current price would be $165 USD. I should have sufficient material to throw in a headplate and a bridge.
regards
Tim
Author:  Mark B [ Thu Jul 26, 2007 3:01 am ]
dude i want a set of that, thats sweet. not as much as i would like to have a set of that tiger myrtle.
mark b
Author:  bob_connor [ Thu Jul 26, 2007 10:09 am ]
How well does this stuff bend Tim?
Author:  Aust Tonewoods [ Thu Jul 26, 2007 10:41 am ]
Hi Bob,
I will post an image of some bent minnerichi material later today.
regards
Tim
Author:  Martin Turner [ Thu Jul 26, 2007 9:15 pm ]
Im tempted...Tim see PM.
Author:  Aust Tonewoods [ Thu Jul 26, 2007 10:11 pm ]
Bending Minneritchi
Well Bob here are the images.
I have used Mugla and Minneritchi for bindings and they responded well to the bending process. I found a fretboard piece which I sanded down (2.3mm/0.090") and then free-hand bent the piece over a thermal blanket without any back support for about 5 minutes occasionally adding water. I found there was only minimal fracturing on the edge which is fairly normal given that it wasn't supported. In a proper Fox like bender I believe the process would be relatively painless.
Used some tape to hold it in shape for the image.
Degree of spring after the tape had been removed.
Slight evidence of small fracture to the right of centre bend. Nothing significant.
Author:  PaulB [ Thu Jul 26, 2007 10:22 pm ]
It's amazing how dull these desert acacias look when they are sanded, and then leap to the other end of the spectrum with a bit of water or finish, or even just sanding and polishing.
Wish I had the cash right now to grab a set of this stuff.
Glad to know minneritchi bends well, wouldn't know what to bind my current build with if it didn't.
