Thickness of bending slats http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=12958 |
Author: | Shane Neifer [ Wed Jul 25, 2007 5:42 am ] |
Post subject: | |
Those of you using blued spring steel, how thick are your slats? Thanks Shane |
Author: | Michael Dale Payne [ Wed Jul 25, 2007 6:25 am ] |
Post subject: | |
Shane I believe most people use .010" or .012" I like .08" for the bottom of my sandwich and .040" between the wood and blanket but I like to use .012" on the outside between the press cauls and the blanket. Yes I use 3 per sandwich. |
Author: | TonyKarol [ Wed Jul 25, 2007 8:13 am ] |
Post subject: | |
mine are .010 Shane .... |
Author: | tippie53 [ Wed Jul 25, 2007 8:19 am ] |
Post subject: | |
I use .o15 , they are heavy enough to support the wood if it tries to move . Also it helps to add "thermal mass" for more consistent heat. I tried alot of different sizes from . ,040 and .080 are very heavy and won't get into tight curves. Are you sure they are so think? john |
Author: | Michael Dale Payne [ Wed Jul 25, 2007 8:47 am ] |
Post subject: | |
John you are right I doubt you could bend .040" arond a telephone pole smoothly ![]() |
Author: | Colin S [ Wed Jul 25, 2007 8:49 am ] |
Post subject: | |
Mine are whatever thickness John Hall sells. I figured that a man that bends that many sides knows the right thickness steel to use, so just bought them from him. Work perfectly. I don't believe in reinventing the wheel. Colin |
Author: | Shane Neifer [ Wed Jul 25, 2007 9:31 am ] |
Post subject: | |
Thanks for the feed back..... Shane |
