It is currently Wed Aug 13, 2025 9:45 pm
PostPosted: Wed Jul 11, 2007 7:52 am
I have a question for those in the know. When you inlay the big block mop into a 12" radiused fb do you radius the back of the pearl, or just install flat and sand the radius into the top of the pearl? Seems like on a block that big and a radius that tight one would have to radius the back of the mop to keep from screwing up the good looking layers on the surface during sanding.
PostPosted: Wed Jul 11, 2007 7:56 am
The back of the pearl is flat. When you sand the radius on the top you can cut through the pearl at the edges, so it is required that you use thicker pearl. Usually the 0.060" blanks are sufficient.
PostPosted: Wed Jul 11, 2007 8:25 am
same as Barry. inlay flat sand to radius
PostPosted: Wed Jul 11, 2007 9:00 am
I third
PostPosted: Wed Jul 11, 2007 10:25 am
Thanks guys, that's what I've done on all my previous mop inlay, I've just never done one as large as those blocks.
Install flat and sand her level. Okie dokie.
ron
PostPosted: Thu Jul 12, 2007 11:09 am
Last Name: Garrish
With a perfect pocket, you can get around 2.15" of play out of a piece of pearl 0.05 thick on a 12" radius. I'll go to 2" wide, and I'd say it's totally attainable to do 1.85-1.9" by hand.
Scaling all those numbers, a 0.06 piece of pearl can ideally get around 2.3", and so you can probably do 2-2.1" by hand.
Not sure it helps, but it's food for thought. I often have to map these things out when designing inlays.
Bob Garrish
