Yellow Siris sound characteristics http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=12548 |
Author: | Mackie [ Thu Jun 21, 2007 10:53 pm ] |
Post subject: | |
Can I get some opinions on the sound characteristics of Yellow Siris from anyone out there that has built with it or played a acoustic guitar made from It? I'm about to start building a Weissenborn, and I'm interested in using this particular wood because of the way It looks and the price, but I am more concerned with the sound that it will produce above all else. I'm particulary concerned with the wood being descrided as light and soft, can this possibly effect the sustain? Thanks in advance for your opinions. |
Author: | Mackie [ Thu Jun 21, 2007 11:14 pm ] |
Post subject: | |
Sorry for the double post. Thought I lost the first one Moderator feel free to delete one. |
Author: | Daniel M [ Fri Jun 22, 2007 3:56 am ] |
Post subject: | |
I built a Weissenborne type guitar with sirus last year & the owner is very happy with it. The sound is quite mellow & very even across the strings. I found that the bass needed a bit of punch, so went one guage heavier on the bass string. The owner plays it in open "C" now & uses medium strings with good results. The highs are very clear & smooth, right up to the top of the fretboard. I did change the bracing patten from the original plans, using a more standard X pattern. The low profile, fat braces on the plans just didn't look right to me. Siris is super easy to bend (not that that's an issue with a Weissenborne) but it is softer than most hardwoods & will dent quite easily. I am just finishing a siris OM Venecian cutaway. It's not strung up yet the the box taps with a nice bassy ring. The figured siris is very pretty under finish. It glues well & is very stable. No cupping in the sides & very little springback. If you are buying siris for a Weiss, see if they can send you a chunk to make the peghead & blocks. You'll get a much better colour match that with mahogany. Oh yeah... The dust makes me sneeze! Good Luck! Dan |
Author: | Mackie [ Fri Jun 22, 2007 4:40 am ] |
Post subject: | |
Thanks for your sharing your experience with Yellow Siris Daniel, It sounds like a very promising wood. I would like to get a chunk for the peghead as well If I decide to try it. When you say "blocks" are you suggesting that It be used for the tailblock? |
Author: | Daniel M [ Sat Jun 23, 2007 3:37 am ] |
Post subject: | |
The head block will be exposed on the back side where the block tapers into the peghead. I used sirus for this piece. (I think I used H. mahogany for the tail block.) This is another place & didn't follow the plans. I made the head block & peghead in one piece. It is easier & stronger than using a M&T joint. After the summer is past, I'll be building two more Weiss type guits. I'm trying to find some ribbon grain Sapele sets for them. It'll be interesting to compare the finished instruments. Have fun with your project! Cheers, Dan |
Author: | Mackie [ Sat Jun 23, 2007 10:26 am ] |
Post subject: | |
Daniel wrote: I made the head block & peghead in one piece. Daniel, you did the right thing by making the peghead and head block one peice on your Weissenborn. I plan on doing the same. Thanks for your help. |
Author: | peterm [ Sat Jun 23, 2007 1:07 pm ] |
Post subject: | |
never seen one but would love too. |
Author: | Daniel M [ Sun Jun 24, 2007 4:22 am ] |
Post subject: | |
Hey Peter; There are pics of three Weiss type guitars on the Cloud Forest Products website... In the "Guitar gallery" section. They're an OLF sponsor, so the site has a link at the top of this page. Cheers, Dan |
Author: | peterm [ Sun Jun 24, 2007 6:04 am ] |
Post subject: | |
Thanks, I will check it out. |
Author: | Mackie [ Wed Jun 27, 2007 11:55 pm ] |
Post subject: | |
Daniel M wrote: There are pics of three Weiss type guitars on the Cloud Forest Products website... In the "Guitar gallery" section. " Daniel M, Did'nt you build one of the Weissenborns shown in the "Guitar gallery" section? I'm awaiting a Yellow Siris sample. |
Author: | Daniel M [ Fri Jun 29, 2007 5:17 pm ] |
Post subject: | |
Yeah, one of those guits is mine. Robin & Marshal of Cloud Forest Products are neighbours of mine. I resawed a small batch of siris for them & they gave me a Weis set & a guitar B&S set in exchange. Dan |
Author: | Mackie [ Sat Jun 30, 2007 8:54 am ] |
Post subject: | |
I thought that was your Weiss. Very nice. |
