It is currently Fri Aug 01, 2025 9:56 pm
PostPosted: Fri May 18, 2007 4:34 am
For those of you that use a blanket,
In what order do you make your sandwich before it heats up and goes on the mold? (ie. slat, blanket, wood, slat etc.) Will the wood being in direct contact with the blanket scorch it?
thanks
PostPosted: Mon May 21, 2007 3:14 am
Slat,wood rapped in moist kraft paper or alluminim foil, slat. this then placed on the mold. Then heating blanket,slat on top of the sandwich
PostPosted: Mon May 21, 2007 3:58 am
I used the same type of stack Hesh describes.
