It is currently Sun Aug 17, 2025 11:26 pm
PostPosted: Fri May 18, 2007 12:48 pm
Anybody make their own router base for a dremel for routing for inlays?  I'd like to see pics so I can make one for my dremel. Thanks Rich
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Fri May 18, 2007 7:42 pm
First name: Martin
Last Name: Edwards
Naw, I bought the Dremel brand one.
It's bigger than the stewmac version.
when I eventually need a replacement I'll prolly go with the stewmac one
PostPosted: Fri May 18, 2007 7:46 pm
Martin, have you looked at Madinter recently? They now sell, what seems to be the same Dremel attachments; base, circle cutter, edge guide as SM do.
PostPosted: Fri May 18, 2007 7:53 pm
First name: Martin
Last Name: Edwards
a new supplier!!
yay!!
prices look good too.......
PostPosted: Fri May 18, 2007 11:39 pm
I just use the stewmac one.  It work very well and is worth the price IMO.  I kicked the idea of making one around but decided that it was probably less expensive to buy a ready made one, and it saved time too.  I like making my own stuff, but sometimes it is just more practical to purchase a ready made unit.
PostPosted: Sat May 19, 2007 12:52 am
I also use the StewMac base. I also have made a second base for mine, without the cut-out in front. I used the Dremel/router base to cut binding channels on my mandolin pegheads, and needed more support area than the standard baseplate provided. Made a replacement out of model aircraft plywood, and the problem was solved. Will now make one of aluminum.
Another thing - if you're using the edge guide on the StewMac router base on something that's relatively thin (like, say, a mandolin peghead) the edge guide hangs too far beneath the surface of the base to be useful. At the hardware store I found a nylon spacer I could cut to use as a smaller roller guide, and a #4 screw with a nut, and reverse the edge guide roller so it extends upwards from the little support arm instead of below it. This prevented me having to spend $38 on the new adjustable StewMac binding routing attachment.
Rick Jones
Rochester Hills, MI
http://home.comcast.net/~rajones19
