It is currently Sun Jul 27, 2025 4:42 am
PostPosted: Sat Apr 14, 2007 12:21 am
On my second build that I finished last November the bridge partially came off the soundboard. The interesting thing is that it lifted on the bass side wing and about 1/2 the backside,on the bass side. I know normally it tends to lift on the back. I'm starting to wonder if the top sunk on that side. I used HHG, has anyone used fishglue? Clinton
PostPosted: Sat Apr 14, 2007 2:12 am
I have a question..... did you radius sand the back side of the bridge before you glued it up? If so, how did you sand it and did both wings lay down on the top before you glued it up?
PostPosted: Sat Apr 14, 2007 2:31 am
Well then I better keep to familiar ground:HHG & Titebond. I did radius the bridge and caul and I thought it layed on the soundboard nicely. I just thougt it was weird to have lifted in the manner it did. Clinton          ;           ;           ;           ;
PostPosted: Sat Apr 14, 2007 4:25 am
I've used fish glue on well over a hundred bridges without problem, but
other than ease of use I certainly would never argue it to be any better than
hide glue. If the glue was good quality fresh hide glue than it was not the
cause of the problem. Extreme humidity changes, collapsing or serious belly
in the top, poor fit and preparation, or perhaps cooling and gelling of the
glue before full clamping would be the most common causes of premature
lifting.
PostPosted: Sun Apr 15, 2007 7:03 am
David, thanks for the input. I bet it was one of the reasons you stated. Thanks Clinton
