It is currently Thu Aug 21, 2025 8:54 am
PostPosted: Thu Mar 01, 2007 7:38 am
Hi gang,
I've been looking around for a saddle slot routing jig without much success.
Wondering if anybody knows of a maker (besides the StewMac version), or if
anybody has plans to make one.
If it helps, I own a Dremel, a Black & Decker router and am not opposed to
buying another router to have just for this purpose.
I also have a drill press but it doesn't seem like a good choice for this
operation.
Any help is appreciated,
Chris
Christopher C. Cordle
North Muskegon, MI
PostPosted: Thu Mar 01, 2007 7:50 am
Check out John How's jig in the "Jigs, Tools & Techniques" section. I made one and find it to be a solid design.
PostPosted: Thu Mar 01, 2007 9:12 am
In the John Mayes video on bridge making I remember that he uses a drill press rig that consists of an end mill bit and a sliding vise. Looked pretty straightforward and uncomplicated. Check out the video available from John's website or for rent at smartflix.com.
Crowduck
Chris Nielsen
Soquel, CA.
PostPosted: Thu Mar 01, 2007 10:00 am
Last Name: Abercrombie
Chris-
Do you want a jig to cut the slot before the bridge is glued to the guitar, or after?
The John How jig is a good example of the former.
The Don Teeter book (Vol 1) has 'plans' for a simple guide for the Dremel to cut slots in bridges that are on guitars. I think he had some info on slotting when you are making the bridge as well.
I've never had much luck using the drill press as a router for stuff like this.
If you can build a guitar, you can build this type of jig quite easily.
One tip-no matter what type of jig you are using- is to get a piece of steel rod (1/4 or 1/8 depending on your router) and put a point on it (drill press and grinder, or hand-held drill and bench grinder). Chuck it up in the router when you are lining things up and clamping down the jig, then switch to your cutter bit.
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
The most amazing jig I ever saw was made by David Collins of Collins Lutherie.It used a Porter Cable Trim router and had laser guiding.Virtually impossible to goof up.It had a plunge feature and front and back stops.It was really a work of art.I watched him use it to Re- rout a saddle on my guitar.David is a member of this forum and an all around great guy.
                              James W B
James W Bolan
Nashville Tennessee
PostPosted: Thu Mar 01, 2007 10:46 am
[QUOTE=JohnAbercrombie] Chris-
or after?
John,
I'm looking to route the slot before attaching to the guitar.
I'm sure I could make one but have not seen any good plans.
Just trying to prevent re-inventing the wheel if someone already has a
proven design.
North Muskegon, MI
PostPosted: Thu Mar 01, 2007 10:54 am
Chris-
Another variable to consider is whether you are going to use a standard cutter and size the saddle to the slot, or whether you will want to make non-standard slots, and will have to move the router/bridge for multiple cuts.
If the former, then you just need to make up some rails to guide the router side-to-side. Then a fixture to hold the bridge under the router- John How's jig would be a good start.
PostPosted: Fri Mar 02, 2007 5:58 am
I think the stew-mac version is around $125. I've used it several times and have found it to be extrememly handy. I may have to look into making my own, though. I'll have to check into the references above.
Any photos available of the Collins jig?
-j.
-jack handy
PostPosted: Fri Mar 02, 2007 8:04 am
We got to see the Collins jig at the last MGL meeting. It's quite impressive, and quite complicated at a glance. He'd probably have to disassemble it for photos to make any sense. I asked him if he had plans drawn for it, but he doesn't--made it up as he built it (durn inventors!). It also includes expensive linear bearings, though he got his at a bargain from Ebay.
