It is currently Sat May 16, 2026 8:24 pm
PostPosted: Tue Jan 16, 2007 7:15 am
Hi, I was wondering whether or not I could make guitar parts such as bridges and necks with alibre xpress and meshcam? The xpress version I have exports to .stl what do you think?
PostPosted: Tue Jan 16, 2007 12:52 pm
Bridges probably and necks probably not, well at least not the heel. Don't know this for a fact, just a best guess from working with may CAD /CAM packages.
PostPosted: Thu Jan 18, 2007 9:50 am
Hi from Germany,
I use for 3D design for acoustic guitar bridges ("normal" Martin & Pyramid bridge) Rhino3D. For me it works very well. You can buy a CAM-addon, too.
English website: http://rhino3d.com/
For controlling the routing I use a German based tool that won?t help you, I guess. But it works fine. ;-)
Just my 2-cents, hope it helps.
Best regards,
Martin
http://www.best-EuroSpruce.com
PostPosted: Thu Jan 18, 2007 11:29 am
Last Name: Garrish
Those programs will do necks. Alibre has lofts which is all you really need to model a neck (although, from my ten minutes messing with it, I wouldn't want to work in Alibre :) ).
MeshCAM uses parallel toolpaths which is enough to cut a neck out, except that you will have to do the tenon by hand if you're going that way as you can't cut a vertical corner with a round mill.
If you've got money to spend, Rhino is what I (and John Watkins, and many others) use for CAD. For CAM, it's all about what features you need and if it's just roughing parts out then a lower end package like MeshCAM fits the bill. If you are a student, though, you can score Rhino and MaDCAM for $400 all in which is a pretty good combo and and capable of a lot more than MeshCAM is.
Bob Garrish
