It is currently Sat Aug 16, 2025 9:00 pm
PostPosted: Wed Jan 17, 2007 11:35 am
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
I haven’t posted much recently simply because I have some cool projects
going on! So I thought I would share a few with you.
First, I have been developing my skills working with aluminum and trying
to think like a machinist. A few weeks ago I happened upon a small
milling machine on my local Craig’s list. I bough it thinking if it's good
for nothing else it would make a great saddle-slotting rig.
Mill
This tool has been very useful and it cuts the nicest slots in bridges.
Here's a picture of a bridge with the milled slot below and a slot cut on
my drill press above.
Milled Slot
I've been working on building a carving duplicator to rough out archtop
plates. So far I've got the carriage built minus the router mount and I'm
beginning to get the rails and linear bearings lined up.
Here's a preview:
http://www.freilicherguitars.com/OLF/carvingduplicator/
Enjoy!
Louis
PS- Sorry, I still can't get pics to upload or link from my site!
- Louis Freilicher
PostPosted: Wed Jan 17, 2007 4:51 pm
[QUOTE=Louis4052] Here's a picture of a bridge with the milled slot below and a slot cut on
my drill press above.[/QUOTE]
Wow! Nice and clean--can't argue with that! What cutter did you use?
PostPosted: Wed Jan 17, 2007 10:14 pm
   http://www.freilicherguitars.com/OLF/carvi ngduplicator/dupli catorsteup2.jpg
Louis, simply copy and paste the picture location to the little window after clicking the little green tree icon. The UP arrow Tree, allows you to post to the OLF, but presently isn't working for reasons unknown to the general olf populace. Great looking machine sir, and may I say, nice find on CraigsList. What did that set you back? Looks expensive used? ! Bruce
Edit, hmmm, pic didn't load, but I found a blank space in the name, we'll try again after the edit.
PostPosted: Wed Jan 17, 2007 10:22 pm
This software is adding spaces, you are right Louis, only a link is currently working, the pic links are corrupted on publishing?
I give up. And... I'm going back to bed.
PostPosted: Wed Jan 17, 2007 10:23 pm
Well, it had been working, then it didn't didn't didn't did! Hooray.
Nice looking start on a CNCchine....
PostPosted: Thu Jan 18, 2007 12:43 am
First name: Louis
City: Belchertown
State: MA
Thanks Bruce!
The slot was cut with a 4 flute 3/32 end mill. There are some more pictures
of the tool and tool holder on my site.
I'll check in and answer more questions tonight; I'm on my way out to pick
up a metal cutting lathe!
Cheers,
Louis
- Louis Freilicher
PostPosted: Thu Jan 18, 2007 4:46 am
Looking good there Louis! Nice set up!
PostPosted: Fri Jan 19, 2007 3:53 am
First name: Louis
City: Belchertown
State: MA
The mill was $300 and for a small, entry-level machine, I figured that
qualified as a cheep education! Now that I have some experience working it
I want a bigger one!
The mill has replicable collets, similar in function to the 1/4 and 1/2 collets
that you can swap out of larger routers.   I have a set that includes 1/8
1/4 3/8 and 1/2 for the mill. I have some pics of the collets and how they
work that I will try and post.
Louis
- Louis Freilicher
