It is currently Thu May 07, 2026 3:20 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 11, 2007 1:21 pm
[QUOTE=sharp_custom] I'm not whining about prices here. The only reason I ask about ameritage is because I've never seen one in person. It's hard to compare when you've never had one in front of you. [/QUOTE]
If you want to see one shoot me a PM. I have a bunch setting in the shop. If you cover shipping I would be happy to let you borrow one and examine it.
They are custom fit to my guitars and probably won't work on yours, but at least that way you get to look them over before you make the investment.
My personal feeling is they are second only to Calton.
PostPosted: Tue Dec 11, 2007 1:24 pm
[QUOTE=LanceK] A heads up on the discount. You have to order 6 cases that are identical in every way. Same model, color, bindings etc.
Don't ask me how I know this
This batch did not qualify
[/qUOTE]
Maybe you should only offer one color case.
PostPosted: Tue Dec 11, 2007 1:26 pm
They come in pink too - ask Coach tony Karol............
PostPosted: Tue Dec 11, 2007 1:31 pm
[QUOTE=terken]
He said they found the charred case in a cornfield and the banjo was unharmed
Well, you can't catch a break EVERY time.
Alex told me one time that I was their 9th customer. They've got quite a list now.
All the good things have been said and I'd just be repeating them but I'm quite impressed with their work.
The cases they make for my archtops are impressive indeed. They have to be extra thick to handle the height of the bridge/arch. So that makes them weigh a TON. But they fit like a glove and protect like Ft. Knox.
PostPosted: Tue Dec 11, 2007 3:33 pm
Hi - any Canadian suppliers for Armitage or would I have to order direct from the US?  I can't find a Canadian listing on the website and the taxes/duty wouldn't be pretty for me up here.....
PostPosted: Wed Dec 12, 2007 1:06 am
To get luthier pricing you have to order direct
PostPosted: Wed Dec 12, 2007 2:37 am
The tops and backs aren't arched?
 What's the crush rating on these? What;s the tollerance for fit? How many points of reference do they require when fitting them?
Don't fool yourselves. These don't hold a Bic Lighter to a Calton. 1/2 price, yes, and nice and dressy, yes, but not in the same protection league... If you're going to lug a 15 lb case through airports for years and years, only a Calton is a Calton.
PostPosted: Wed Dec 12, 2007 3:02 am
The tops are arched. Due to the construction and the amount of padding and the way they pad the arch in the top is not as apparent from the exterior as on most cases. I have no idea of the crush ratting but will say I have no problem stating that I am sure it is greater than Cedar Creek.
The spec sheet I fill out on each of my models for custom fitting has at least 15 required reference dimension. Their spec sheet is almost idenical to Cedar Creeks. As far as their tolerance I have never had one miss fit my specs.
No grumpy it is not a Calton but I having owned both and Cedar Creek, TKL Pro series and many other cases, I have no problem putting the Ameritage up against any including a Calton. It may not beat the Calton on the exterior ruggedness and total crush rating. It most certainly is not as hard of a shell as a Calton but in every other way I would rate it higher including custom fitting.
PostPosted: Wed Dec 12, 2007 3:03 am
I did not hit the post button yet???? Oh well
PostPosted: Wed Dec 12, 2007 5:01 am
I too use Ameritage...for about 4-5 years now. Super People and a great case for the money...buy them 6 at a time you won't be disappointed. If not, spend the money and buy Calton but you will need to raise the price of your guitar to pay for it. I include my case with the guitar...I don't give any discount if the customer doesn't want the case, it comes with. I won't deliver a guitar to a customer without MY case. So he can show up with an empty Calton and he will leave with an empty one too.
Although, I do remember Bruce Dickey saying he got a great case from Musicians Friend for around $39. You might want to try one of those... Maybe Bruce will chime in...
PostPosted: Fri Dec 14, 2007 6:35 am
[QUOTE=terken]Here is an interesting story. I did a banjo workshop with Pete Wernick in the early 80's and he showed us his travel case. Looked a lot like a Calton but I think it was another brand.
As you may know he was in the Sioux City IA DC10 crash and survived. I ran into a banjo player years later in Colorado that knew Pete and I asked him what happened to the banjo.
He said they found the charred case in a cornfield and the banjo was unharmed Probably safer to be in a crash than go through baggage handling!
Terry[/QUOTE]
I asked Pete about that case yesterday. He said it was made by Mark Leaf Case. He retired it after about 25 years of service! Unfortunately it is no longer produced. He now uses a Price case and finds it better than the Leaf Case.
Anyone tried a Price case?
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Fri Dec 14, 2007 6:42 am
[QUOTE=grumpy] The tops and backs aren't arched? What's the crush rating on these? What;s the tollerance for fit? How many points of reference do they require when fitting them?Don't fool yourselves. These don't hold a Bic Lighter to a Calton. 1/2 price, yes, and nice and dressy, yes, but not in the same protection league... If you're going to lug a 15 lb case through airports for years and years, only a Calton is a Calton.
<div style=": ; width: 28px; height: 28px; : 1000; display: none;">
Mario, do you use Ameritage? Have you seen them in person?
PostPosted: Fri Dec 14, 2007 6:53 am
I've seen a few, but no, I don't use one.
PostPosted: Fri Dec 14, 2007 7:01 am
and you can honestly say "Don't fool yourselves. These don't hold a Bic Lighter to a Calton"
I have seen both. That statement is an over exaggeration.
I would not say that Ameritage cases are stronger than a Calton, but calling them a Bic Lighter by comparison is wrong. That kind of statement makes then sound like there no better than a 99.00 TKL found at your local Guitar Center.
They have an extreamly good fit.
They ask for 14 points of referance when building a custom case, Calton askes for 15.
The top is arched. Back is flat. I suspect that you could order an arched back if you want.
PostPosted: Fri Dec 14, 2007 2:29 pm
Country: Romania
I have a good deal of experience with the Cordura fabric.  My other hobby is mountain climbing, Cordura is used for backpacks, gaiters, crampon bags, stuff that gets really abused and it holds much better than generic nylon fabrics.
Build log
PostPosted: Fri Dec 14, 2007 3:37 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Interesting thread.
I used some Ameritage cases back "last century" in their previous incarnation (different management, etc)and found them to be very nice, indeed. Drifted away to the (then) Harptone Cases as they had a wide variety of sizes/shapes available that fit my various instruments. They went away to TKL and the available sizes seemed to get lost in the shuffle. Even using the Cedar Creek side of the house didn't help and order times just dragged out.
So, having decided to get back in touch with Ameritage, I sent them an email on 12-11-07 asking for details that would suit my instruments. Well, so far, I have had no response. Not an auspicious start to a revitalized relationship.
There ought to be one hell of a business for a case company that could get the act together and deliver a reliable product on a reliable timeline. Are any of those companies listening...Access, TKL/Cedar Creek, Ameritage???
Hank Mauel
