It is currently Thu Sep 18, 2025 11:45 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Post subject: Temp controller
PostPosted: Mon Sep 28, 2020 6:32 am
Who uses a temp controller when bending to maintain constant temperature? If so which one do you employ?
Considering upgrading the “thermometer method”:)
B
 Post subject: Re: Temp controller
PostPosted: Mon Sep 28, 2020 10:03 am
Last Name: Colbert
City: Anacortes
I’ve been using one of these for the last 10yrs. The thermocouples are the weak link. I buy replacement ones on Evil-bay
https://www.lmii.com/bending-heating/19 ... -volt.html
These users thanked the author Michaeldc for the post: SnowManSnow (Mon Sep 28, 2020 10:18 am)
PostPosted: Mon Sep 28, 2020 10:19 am
That’s the one I was looking at.
I can manage without one, but as I put together a new area I’m wanting to get away from “I manage” ha
PostPosted: Mon Sep 28, 2020 10:24 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I assembled my own which I found, after the fact, used the same digital controller as shows up in the LMI tool. Lots of time spent. If I had the money to spare, I'd buy the LMI device and concentrate on building guitars. And yes the controllers are luxury itself to watch, holding temperature within a degree! Sure beats light bulbs in a box.
Peter Havriluk
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
The LMI unit is a solid design. If you’re so inclined, you can build your own with readily available parts, but there’s no guarantee you’ll actually save any money doing so. See:
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=49239&p=683778&hilit=Controller#p683778
These users thanked the author Tim Mullin for the post: SnowManSnow (Mon Sep 28, 2020 10:30 am)
PostPosted: Mon Sep 28, 2020 10:47 am
Last Name: Colbert
City: Anacortes
As an additional safety feature, I added a pair of motor rated digital timers that are wired in series. I used to use a single rotary timer but after a while it began to stick on, very not good!
M
These users thanked the author Michaeldc for the post (total 3): joshnothing (Sat Nov 13, 2021 5:44 am) • Durero (Sat Jan 16, 2021 5:44 pm) • Pmaj7 (Tue Sep 29, 2020 11:06 am)
PostPosted: Mon Sep 28, 2020 11:16 am
Put my own together, been using it for 4 1/2 years now.
http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=47715
Made a basic wooden box with gaps for heat dissipation and stuck everything inside.
Bought a mechanical timer switch in B & Q, use that on the supply for safety.
https://www.diy.com/departments/diall-1-hour-mechanical-timer/800766_BQ.prd
PostPosted: Mon Sep 28, 2020 11:27 am
Michael, is every tool you own bad ass?
These users thanked the author James Orr for the post: Michaeldc (Mon Sep 28, 2020 12:10 pm)
PostPosted: Mon Sep 28, 2020 11:29 am
M
I don’t understand anything you just said haha
PostPosted: Mon Sep 28, 2020 11:38 am
I think he means electronic belt and braces - if one fails to stop, the other should work. Chances of them both failing on the same run are very small.
I never, ever leave my shop when I'm side bending anyway.
These users thanked the author Colin North for the post: SnowManSnow (Mon Sep 28, 2020 11:53 am)
PostPosted: Mon Sep 28, 2020 12:09 pm
Last Name: Colbert
City: Anacortes
Perzactley!!
I don’t leave my shop either but I have gotten distracted...
PostPosted: Mon Sep 28, 2020 12:11 pm
Last Name: Colbert
City: Anacortes
It’s one of the best reasons to have a CNC. [:Y:]
PostPosted: Mon Sep 28, 2020 1:46 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I can confirm. Every tool in Michael's shop is indeed bad ass. As is his shop.
These users thanked the author J De Rocher for the post: Michaeldc (Sun Oct 04, 2020 10:36 pm)
PostPosted: Mon Sep 28, 2020 4:07 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
Hey Michael, care to share a link to those eBay thermocouples you’re using?
Pierre
Pierre Castonguay
PostPosted: Mon Sep 28, 2020 4:38 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
On Amazon, these work well (although I buy mine from Amazon.ca):
https://www.amazon.com/uxcell-Measuring-Thermocouple-Sensor-3-3Ft/dp/B00J2N3QQQ/ref=sr_1_11?dchild=1&keywords=K-type+500c&qid=1601328736&sr=8-11
Main thing is rating of 500°C(800°F) or higher. I consider these to be consumables. My handheld temperature meter uses the same K-type thermocouple, so I usually have it running alongside my blanket controller.
These users thanked the author Tim Mullin for the post (total 2): Pmaj7 (Tue Sep 29, 2020 11:14 am) • Smylight (Mon Sep 28, 2020 5:05 pm)
PostPosted: Mon Sep 28, 2020 5:15 pm
Last Name: Ball
I have the parts to put a controller together, but haven't gotten around to it--I babysit the bender when I'm using it anyway, so manual has always been fine (although I did get the parts together for a controller....). Using John Hall's basic method has always worked well for me. For you folks who are using controllers, Is it really enough better to use the controller when you're already watching it closely to make it worthwhile?
PostPosted: Mon Sep 28, 2020 5:17 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
PostPosted: Mon Sep 28, 2020 8:50 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Dave: my answer is yup, the digital controller offers precision that can't be otherwise approximated. Ain't no way I'm going to manually hold a heat blanket to 300 degrees, plus or minus a half-degree, even if I had an electronic thermometer driven by a thermocouple in the stack in the bender. I've got that setup on my bending pipe and it's not anything close to similar to using a digital controller.
Peter Havriluk
These users thanked the author phavriluk for the post: Pmaj7 (Tue Sep 29, 2020 11:16 am)
PostPosted: Tue Sep 29, 2020 10:10 am
I’ve been building a bending station with a dedicated bench and now I think I’ll add a shelf for a controller.... if it makes my building more precise and avoids potential issues (cracking from not enough heat or scorching from too much) I’m in
PostPosted: Tue Sep 29, 2020 11:17 am
Michael's old shop was badass. I'm sure the new shop is badasser.
These users thanked the author Pmaj7 for the post: Michaeldc (Tue Sep 29, 2020 12:19 pm)
PostPosted: Sun Oct 04, 2020 10:06 pm
First name: Daniel
Last Name: Oates
City: Sharon
State: Connecticut
Zip/Postal Code: 06069
So, where are you guys getting your heating blankets? I’ve seen some on eBay, most are from China for about $100. Are these any good?
PostPosted: Mon Oct 05, 2020 1:32 am
I have been using a Keenovo side bending blanket 5W/sq.in. for 5/6 guitars now and have had no problems so far.
These users thanked the author Colin North for the post: Pmaj7 (Mon Oct 05, 2020 4:46 am)
PostPosted: Mon Oct 05, 2020 5:46 am
I have both but find the thermometer a lot easier. The issue with PID transducer , if it is attached to the blanket you only know heat at that point
with the thermometer you can move it and check other points. No matter how good with the water on the wood temps vary until the wood dries off so
be sure you know your blanket. 5 watts per in will have less temp drop than a 2 1/2 .
These users thanked the author bluescreek for the post: Pmaj7 (Wed Oct 07, 2020 11:26 am)
PostPosted: Mon Oct 05, 2020 7:37 am
First name: Daniel
Last Name: Oates
City: Sharon
State: Connecticut
Keenivo is the brand I’m looking at on eBay.
PostPosted: Mon Oct 05, 2020 9:40 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I've been using the keenovo blankets for about a dozen guitars. I also use the temp controller. It's OK, but you definitely need to keep an eye on things. Not nearly as good as what I hear the LMI controller does.
Tony Thatcher
Bozeman, Montana
Users browsing this forum: Cal Maier and 33 guests
