http://www.luthiersforum.com/forum/
Installing K&K pure mini
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=50416
Author:  bcombs510 [ Mon Mar 12, 2018 9:19 am ]
Post subject:  Installing K&K pure mini
Hello,
I'm going to be putting K&K's into two new builds I'm working on. I thought about installing them onto the soundboard before I close the box, but then starting thinking about keeping the wires out of the way while drilling and reaming the pins.
Anyone install these in advance like that? I think I can just bundle up the wires and tape them above the bridge plate. Should be fine, right?
Brad
Author:  johnparchem [ Mon Mar 12, 2018 9:40 am ]
Post subject:  Re: Installing K&K pure mini
bcombs510 wrote:
Hello,
Brad
I have done it that way. The wires have a big enough loop so it is not hard to keep them out of the way. While finishing the instrument I secure the socket end with tape to the bridge pin to keep it from banging around.
Author:  bcombs510 [ Mon Mar 12, 2018 9:58 am ]
Excellent. Thanks, John!
Author:  Ken Lewis [ Mon Mar 12, 2018 10:28 am ]
Do it now, for sure.imo, (unless you're really looking forward to sticking those things on
through the soundhole) :)
Ken
Author:  Casey Cochran [ Mon Mar 12, 2018 11:03 am ]
The pin holes are a great reference for a precise installation.
Author:  Woodie G [ Mon Mar 12, 2018 11:34 am ]
We prep for install prior to the body being closed for systems such as the Anthem or other PSA-mounted items that benefit from the area being shellacked, but the K&K elements are very sensitive to minor siting issues, so we do them after construction.
Author:  WilbPorter [ Mon Mar 12, 2018 12:49 pm ]
"... but the K&K elements are very sensitive to minor siting issues, so we do them after construction." That would be my concern too.
Author:  Terence Kennedy [ Mon Mar 12, 2018 3:30 pm ]
Placement is so important that I would always do it after the bridge is on. I noticed that the most recent instructions from K&K have you putting the high e transducer directly under the e string and the remainder as before between the pin holes.
Their simple jig has always worked well for me.
Author:  mountain whimsy [ Mon Mar 12, 2018 3:43 pm ]
I agree with installing at the end. They install so easily with the jig that I would hate to be off on the placement.
