It is currently Tue Apr 28, 2026 9:45 am
 Post subject: FP in tight corners
PostPosted: Tue Jan 17, 2017 12:55 pm
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
Just curious as to how you French Polishers get into those tight corners like the heal/side. My first is frenched and I've been using that to teach me so I'm fairly new at it but have a good feel for it so any FP info is helpful thanks in advance.
 Post subject: Re: FP in tight corners
PostPosted: Tue Jan 17, 2017 1:03 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Make a smaller pad for the tight spots, give that smaller pad a chiseled tip, use something thin to nudge the smaller pad into corners, work pretty dry, don't let loose parts of the pad get gunk on them, don't let any such loose parts touch the parts of the guitar to which you are not depositing material. That sort of stuff. Lord knows I'm no expert, but that's what I try to do.
PostPosted: Tue Jan 17, 2017 1:17 pm
Making a small triangular pad usually solves the problem
PostPosted: Tue Jan 17, 2017 1:37 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
for those corners, I wrap linen around one of those big red pencil erasers that are rectangular but with tapered ends. Makes it easy to apply right to the sharp inside corner,
PostPosted: Tue Jan 17, 2017 2:20 pm
Fast circular strokes. When done I use finishing papers and swirl remover polish to get rid of any marks. It's a PIA around the bridge in particular or any area of cross grain. Along the fretboard is easy since it goes with the grain and with your longer strokes of the pad.
PostPosted: Tue Jan 17, 2017 3:49 pm
The redish/pinkish erasers are OK, but will start to bleed into the shellac, eventually. I find the art gum or the artists white erasers to work better and last longer. I cut them into shapes that work for me, but around the bridge or neck, on the sides, a square isn't too bad.
These users thanked the author WaddyThomson for the post: Imbler (Tue Jan 17, 2017 7:39 pm)
PostPosted: Tue Jan 17, 2017 4:33 pm
Last Name: coleman
City: rome
State: ny
Great ideas everyone thank you bunches. Love frenching but when in pieces is soooo much easier lol
PostPosted: Fri Jan 20, 2017 1:34 pm
Use a smaller, looser pad.
I do the most part of my FP before gluing the neck into the body, so it has a decent build-up at the joint already. Then after the guitar is set up and playing, give it a couple of weeks and remove the strings & machines and take care of any FP "issues" in a final way before shipping.
PostPosted: Sat Jan 21, 2017 8:50 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
To get into tight corners like at the heel I put a bead of shellac down the inside of the angle with a brush before starting polishing. This gives some shellac in the hard to reach area to work with. When I get to that end I load my mouse as usual but instead of tamping and blotting on a flat board I push and tap into a small inside corner block I have to form one side at a 90 degree to the bottom and viola....just polish into and out of the corner from both sides.
Brian
PostPosted: Sat Jan 21, 2017 10:04 am
Great tip, Brian!
Users browsing this forum: No registered users and 41 guests
