| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Tricky Fret Board Inlay http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=46986 |
| Author: | printer2 [ Tue Jan 05, 2016 7:35 pm ] |
| Post subject: | Re: Tricky Fret Board Inlay |
All I can think of is score into the surface and then some white epoxy, not hard enough though. That does look cool. |
| Author: | tysam [ Tue Jan 05, 2016 7:49 pm ] |
I had a client who gave me a container with a liquid plastic in it, Pat. It poured and flowed nicely but it dried very hard. The cool thing about it was it was white and glowed in the dark. ( I used it for oversized fret markers for him). I'll try and reach him and get a name from him. That may work for you and fit in to the concept at the same time. |
| Author: | DennisK [ Tue Jan 05, 2016 7:56 pm ] |
Hmm, that is a tricky one, but also very cool. I want to suggest the technique of sawing all the way through with a jeweler's saw and then sticking veneer in the slot to do the fine lines, but with them all intersecting like that it would be in pieces by the time you got all the lines cut Make the big pieces from a good hard material like white MOP or corian, and after routing their pockets, freehand the fine lines. Get various thickness of pearloid sheet if using MOP, or fill with white epoxy if corian. I doubt wear would be an issue for anything but the big pieces, or perhaps any lines that happen to be underneath a string and in line with it. |
| Author: | Ruby50 [ Tue Jan 05, 2016 9:28 pm ] |
I don't have any ideas on how to do this, but I have to say it will look pretty spectacular if you pull it off. Ed |
| Author: | Rod True [ Tue Jan 05, 2016 9:37 pm ] |
I don't think that would be too difficult actually, just very time consuming. I'd do it from white pearl and I'd section it off based on the spots between fret slots. Treat each segment as it's own inlay. Make the "blobs" then make each vein/arm individual. Cut out the pearl first, keeping it on a work board of the print out. Once the pearl is cut start to position it on the board, working just on one section at a time. Place the "blob" down and draw around it with a 0.005" mechanical pencil. When routing cut just to the inside of the pencil line. Ebony for the board will be your friend. Just keep working at it, routing, testing fit, pressing each piece in and fill with CA. Then level the pearl. Move onto the next section. Make sure the board is radiused before inlaying. |
| Author: | Guitarizzmo [ Tue Jan 05, 2016 9:54 pm ] |
I looked for some pictures of neurons, and wanted to put some here, but my clipboard is flipping out (Linux Ubuntu) at the moment, and the bug isn't fixed yet. Point is they have more detail/color variation that may make it even more challenging than just the shape. There are some microscopic photographs as well as artist renditions, the latter are often colored to separate the individual parts, so you have choices. cutting the fingerboard may be fairly easy since they are irregular, just like free form cuts with a rotary tool in a base. they could be filled with bone dust or fine bright wood rasping's and in epoxy. How to get the cell centers right as they have color more or less, may just be a matter of adding dye to the dust before mixing. That's what you get for having smart children Pat! |
| Author: | Gasawdust [ Wed Jan 06, 2016 8:42 am ] |
You might want to consider Inlace. |
| Author: | Guitarizzmo [ Wed Jan 06, 2016 10:48 am ] |
Gasawdust wrote: You might want to consider Inlace. Well there is something I have not heard of yet! Thanks Gasawdust! Darn search engines, where is this information when you need it? I have been looking for more and different inlay materials! Going to read up on the stuff now. |
| Author: | Pat Hawley [ Wed Jan 06, 2016 11:00 am ] |
Thanks all for your interesting ideas. Thanks to Tom, I've spent the last couple of hours reading up on casting - starting with the Inlace. One of the more intriguing things I came across is Alumilite. Here's a link: http://www.alumilite.com/store/p/934-Al ... Resin.aspx Does anyone have any experience with this stuff? Think I could just pore it into my routed out fret board and sand it smooth? If that would work, that certainly opens up a lot of doors for inlay ideas. Pat |
| Author: | Gasawdust [ Wed Jan 06, 2016 12:07 pm ] |
I have used Inlace on filling knot voids turning ugly into unique. It grinds easily in a coffee bean grinder. I used some in a fretboard inlay on Charles Schultz characters where the pieces were too delicate for my jeweler's saw and tired old eyes. |
| Author: | Gasawdust [ Wed Jan 06, 2016 12:17 pm ] |
One more thing to consider...titanium dioxide.....the whitest of whites. If you can get access to some, try it in slow set epoxy. It's used primarily as paint pigment and in it's produced form it is a superfine powder. I could try to send you and ounce or two if interested as I have access to tons of it. |
| Author: | Kevin Waldron [ Wed Jan 06, 2016 12:28 pm ] |
Suggest laser! ( If you don't have access find a sign or trophy shop.) Place template on copier make copy...... then scan.......you now have a computer file that is typically a Tiff file(bitmap)..... (Kinko, UPS etc for scanner/copy) CorelDraw (Laser Operator should have this) has an auto trace program for converting to a vector file for the male part of the inlay........ bitmap is fine for the female part on the fret board. The insert part will need to be probably .003 larger than the cut-out female part....... I'd suggest Corian or similar product for the actual inlay........(works well and is stable and easily glued) Fairly simple after parts made...... You should be able to get this done at a fairly reasonable cost. Blessings, Kevin |
| Author: | SteveSmith [ Wed Jan 06, 2016 1:55 pm ] |
I would probably cut inlays in the traditional sense but it would be a lot of work for sure. Definitely an ebony fret board and I would bind it with ebony after the inlays were done. |
| Author: | kencierp [ Wed Jan 06, 2016 3:08 pm ] |
Actually liquid inlay materials have been around for a very long time -- I think there are many brands if you do a search. Irving Sloane even uses his own formula described in one of his books. Great design should be fairly straight forward transferring the pattern and cutting the rebates. Here's one liquid inlay supplier: http://woodworker.com/turquoise-inlace- ... 46-669.asp |
| Author: | printer2 [ Fri Jan 08, 2016 5:56 pm ] |
Gasawdust wrote: One more thing to consider...titanium dioxide.....the whitest of whites. If you can get access to some, try it in slow set epoxy. It's used primarily as paint pigment and in it's produced form it is a superfine powder. I could try to send you and ounce or two if interested as I have access to tons of it. How about filling the spaces with titanium dioxide and then shooting it with CA? I like the look of the design as one piece rather than multiple segments. Mind you I might like that if I seen it also. |
| Author: | patch [ Fri Jan 08, 2016 10:06 pm ] |
Really great ideas here. I'm looking forward to seeing how you pull this off and with what method. |
| Author: | Ruby50 [ Sat Jan 09, 2016 2:10 pm ] |
I believe that pickguards are mixed and poured from resins. I know of one good luthier who makes copies of 1900-1920 instruments, and he routes the pickguard shape into the top, lays pearl pieces into the recess in a design, then pours the pickguard material into the recess - voila - inlaid recessed pickguard. Ed |
| Author: | Joe Beaver [ Sat Jan 09, 2016 9:26 pm ] |
That does look pretty good Pat. I was going to suggest reconstituted stone but the more I thought about cutting the stone and doing the inlay with that much intricacy and continuous pieces I'm thinking go with the resin. Oh, by the way, A neuron guitar is a very cool idea
