oops advice - Damage repaired http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=46671 |
Page 1 of 2 |
Author: | Alex Kleon [ Mon Nov 16, 2015 6:12 pm ] |
Post subject: | oops advice - Damage repaired |
As the picture show, a bit of grain blow out while routing for bindings. ![]() My thought is to carve the damage out, like this, and glue in a sliver of wood, level, and re-route. ![]() Any other suggestions would be greatly appreciated. The damage is on the treble side, front lower bout, so it will not show too much. Thanks! Alex Sent from my iPad using Tapatalk |
Author: | meddlingfool [ Mon Nov 16, 2015 6:15 pm ] |
Post subject: | Re: oops advice |
Make your bindings a bit taller and add purflings and rout the damage off. |
Author: | Alex Kleon [ Mon Nov 16, 2015 6:38 pm ] |
The binding and purfling is at 1/4" and the damage would need to be routed to 11/32". That's a bit deeper than I'd like to go, Ed. ![]() This is a first guitar, and I'm not having visions of grandeur. I'm sure there will be other blemishes along the way. I'm pretty good at "Dutchman" repairs. Alex Sent from my iPad using Tapatalk |
Author: | Glen H [ Mon Nov 16, 2015 6:46 pm ] |
If you don't want to go deeper, the only option I know of is to shim in a piece. If you can find the blown out chunk, see if it works. I have had luck with that. I personally haven't had great luck using a separate piece. Otherwise, if it looks bad when all put back in, do a burst that shades the sides, and go dark over that spot. |
Author: | johnparchem [ Mon Nov 16, 2015 7:19 pm ] |
If you have not vacuumed that piece is around. I have gotten on my hands and knees until I have found the bit of blown out wood. When it comes out that way the piece is around an most likely intact |
Author: | meddlingfool [ Mon Nov 16, 2015 7:24 pm ] |
Which is why vacuuming after each operation that went well is so advantageous. Narrows down the splinters to sort through... |
Author: | Alex Kleon [ Mon Nov 16, 2015 7:35 pm ] |
meddlingfool wrote: Which is why vacuuming after each operation that went well is so advantageous. Narrows down the splinters to sort through... Cleaned the bench before routing, so unless it shot into the corner of the shop, it should still be there. I made a copy of your binding jig, Ed, and it works great! I'm using a down spiral bit and a bearing guide instead of the rabbeting bits. Another glass of wine and some more olives, and I'll start looking for the splinter! Alex |
Author: | Tom West [ Mon Nov 16, 2015 8:42 pm ] |
Somogyi suggest when this happens to turn it into a decorative feature. Maybe a half diamond shape in ebony. Maybe a matching one on the other side. Lemons into lemonade. I tend to agree with the others re the blown out piece.................if you can find it. Good luck, keep thinking it through before acting. All will work out. Tom |
Author: | meddlingfool [ Mon Nov 16, 2015 9:29 pm ] |
Good luck on your hunt! Been there too many times:) My jig is an iteration of the Ribecke jig, I believe. I like the LMI bits, cause we have a router for each cut and just swap routers. Whomever invents a system like that with a downshear gets some of my money though... |
Author: | DannyV [ Mon Nov 16, 2015 9:46 pm ] |
Put the close up glasses on and find that splinter! Looking good. Going to look awesome. I love the Wenge. If you can't find the piece, wood dust and CA on the treble side of your first guitar would hardly be noticed but I KNOW you could splice a sliver in. |
Author: | Rod True [ Mon Nov 16, 2015 10:00 pm ] |
That sucks Alex. Get some hose (stockings) or thin tee shirt and cover the vacuum nozzle and start picking up the dust/splinters around the area you were working... when the cloth is clogged, turn the vacuum off over a small pan or container, this should reduce your hunting time. |
Author: | Trevor Gore [ Mon Nov 16, 2015 10:10 pm ] |
If you can't find the piece... Did you thin the edges of the soundboard? If not, you may be able to find a millimetre or so there, then rout for deeper bindings, but 1mm less deep than they might have been. You only need to get as deep into the chip as to where the bevel outward starts. A good epoxy grain fill will pretty well hide the rest. |
Author: | Alex Kleon [ Mon Nov 16, 2015 10:36 pm ] |
Sifted through all the shavings on the bench top and found some splinters that might have been parts of the missing piece, but nothing that I could fit together. I cleaned up the damaged area, and managed to get two clamps on a 5/8" patch. Tomorrow will either be a triumph or a do over! I'm not at all upset about this. Stuff happens all the time. If I had take a chunk that size out of my thumb, it would be a different story! This guitar making stuff is fun! ![]() Alex |
Author: | Alex Kleon [ Mon Nov 16, 2015 10:46 pm ] |
Here's how did the bearing guide, Ed. Like most of my jigs, the idea was borrowed from someone else. ![]() The fine adjust is a carriage bolt through an angle bracket, into a barrel nut. Alex Sent from my iPad using Tapatalk |
Author: | Shaw [ Tue Nov 17, 2015 12:56 am ] |
Yeah I would look for the piece. I think matching a piece to a carved out area like you mentioned would be more noticeable. Sent from my SGH-T599 using Tapatalk |
Author: | DennisK [ Tue Nov 17, 2015 1:39 am ] |
Does the guitar have a cutaway? If not, you could turn it into a lefty with a micro armrest bevel ![]() |
Author: | Alex Kleon [ Tue Nov 17, 2015 6:51 am ] |
DennisK wrote: Does the guitar have a cutaway? If not, you could turn it into a lefty with a micro armrest bevel ![]() ![]() ![]() Alex |
Author: | Haans [ Tue Nov 17, 2015 9:10 am ] |
Simplest, putty the area with good dyeable putty, dye the area, apply some Weldon 16, rub into the putty, then sand flat and dye the whole back and sides. |
Author: | kencierp [ Tue Nov 17, 2015 10:51 am ] |
I have successfully used the method described in your initial thoughts -- if you have a matching or similar piece of wood its possible to make a near invisible repair. Glue the splice in with Elmer's do not use CA pay attention to the grain orientation -- the trick is scratch in some grain lines crossing the glue joint then use very fine marker or color pencil to lay in the grain color. Go a little beyond the actual repaired area with the fake grain -- I think you will be surprised how natural this will end up looking. |
Author: | Alex Kleon [ Tue Nov 17, 2015 12:26 pm ] |
Post subject: | Re: oops advice - Damage repaired |
Once the patch was glued and left to completely dry, I sanded it flush with 240 paper on the back of a chisel along with a couple of thicknesses of masking tape so that only the high spot of the patch gets sanded to the same curvature as the side. ![]() ![]() Thanks for all the replies and suggestions. As usual, you folks are the best! Alex Sent from my iPad using Tapatalk |
Author: | WendyW [ Tue Nov 17, 2015 1:14 pm ] |
Nice job! |
Author: | cablepuller1 [ Tue Nov 17, 2015 4:12 pm ] |
Had a similar thing on my build..the router chuck slipped and made a massive mess of my binding channel, taking out a large chunk for a 1/5th of the guitar. . Fixed using extra beading ..turned out ok in the end.. stressful time though Good repair there |
Author: | Tom West [ Tue Nov 17, 2015 4:54 pm ] |
What blowout......................???? Nice recovery..! Alex Looks like you were doing conventional routing at full depth when you had the blow out. I like to go in about .020" to .030" for a primary cut. In my mind less chance of blowout at full depth. Also I like to climb mill, also less chance of blowout. Trevor Gore points this out in his book. When you climb mill you can go all around the guitar in one direction. Thanks Trevor. Tom |
Author: | Alex Kleon [ Tue Nov 17, 2015 6:30 pm ] |
Thanks, Tom! I did conventional route on the four bout areas, and then a 360 climb cut. I'd have to say I should have used a bit more caution than I did. This wood seems to be on the fragile side. I did three crack repairs on the sides early on, although maybe I was a little ham handed. When it is ready for pore fill, I'll be doing what Ken suggested - etching some grain lines, and colouring them. I've done that in the past where I had to repair furniture that I'd built for customers. I would always tell them, but they had to find it themselves! Alex |
Author: | dzsmith [ Tue Nov 17, 2015 7:08 pm ] |
Alex, you showed that blowout who it's daddy is! Nice-un. Dan |
