It is currently Wed Aug 13, 2025 7:36 am
PostPosted: Mon Aug 24, 2015 1:22 pm
What order do you do them in, and why?
PostPosted: Mon Aug 24, 2015 1:34 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I do the back first.
because if there is something wrong with the air pressure-mixture-etc.
Mike Collins
PostPosted: Mon Aug 24, 2015 1:38 pm
Last Name: Collins
City: Argyle
State: New York
it's easier to fix on the back(for me)
Then sides,top last .
I akways take more time on it so it's easier to rub out & so a
mistake is not seen or hard to fix.
Then a single malt!!!!!
Mike Collins
PostPosted: Mon Aug 24, 2015 5:28 pm
State: ON
Sides-back-top. That way I'm not getting overspray from the sides onto the top and back.
But I imagine you can use pretty much any order and get good results.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
These users thanked the author Josh H for the post: jack (Mon Aug 24, 2015 5:30 pm)
PostPosted: Mon Aug 24, 2015 5:45 pm
I spray the body flat. I tape off the fingerboard extension area and the bridge area and then tape a block on those areas to hold the guitar off the turn table. I first spray the top (heavy) and the sides (more lightly) and wait a few minutes for it to flash off. I then flip it onto the blocks and spray the back (heavy) and the sides again (more lightly). I then wait long enough for it to be dry enough to be placed on its back again before spraying a second coat.
PostPosted: Mon Aug 24, 2015 5:48 pm
I spray the sides then the sound board or back. I believe my fixture is a lot different than most. I spray in the horizontal position (like table top) the fixture has a 360 degree locking, rotating work holding detail. I found that the flat spray plane eliminates sag and allows the coating to flow out a little better My fan is down draft so it sucks everything toward the floor away from the work right from the get go.
Ken Cierp
PostPosted: Tue Aug 25, 2015 1:20 pm
First name: Danny
Last Name: Vincent
What Josh said.
PostPosted: Tue Aug 25, 2015 6:33 pm
I use a StewMac Freehand Holder which lets me rotate the body. I spray sides, back, top.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Finishing/Spraying/Freehand_Holder.html
PostPosted: Tue Aug 25, 2015 6:40 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
+1 for Josh H
PostPosted: Tue Aug 25, 2015 7:58 pm
First name: Tom
Last Name: West
State: Nova Scotia
Back, sides,and then top. Why? That's the way I did the first one..................!
PostPosted: Sat Aug 29, 2015 9:31 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Its more about how the light happens to be hitting the instrument as I'm holding it. Whatever part I can see best I spray first typically. I usually start with the top or back I find though.
Users browsing this forum: Cal Maier, JimWomack, joe white, Michaeldc and 20 guests
