It is currently Thu Jul 31, 2025 1:54 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page 1, 2, 3  Next
 Post subject: Warped wood
PostPosted: Wed Aug 12, 2015 5:37 pm
Hello all,
I have a nice board which is warped/cuped. It is about 1/16 inch thick.
Do you have any tips on how should I deal with the warping? I don't want to throw away the piece, which is large enough to build a guitar bottom.
All the best,
Ronaldo
 Post subject: Re: Warped wood
PostPosted: Wed Aug 12, 2015 6:05 pm
Show us some pics?
These users thanked the author meddlingfool for the post: rsfjr (Wed Aug 12, 2015 6:17 pm)
PostPosted: Wed Aug 12, 2015 6:17 pm
Thanks for the reply. As soon as I get home I am going to post some
Sent from my GT-I9505 using Tapatalk
PostPosted: Wed Aug 12, 2015 6:26 pm
Got the thickness wrong. It is about 0.4 inch
PostPosted: Wed Aug 12, 2015 7:14 pm
Like that?Image
PostPosted: Wed Aug 12, 2015 7:50 pm
Yeah
PostPosted: Wed Aug 12, 2015 8:01 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Seriously? Here's what you do
These users thanked the author Mike OMelia for the post: rsfjr (Wed Aug 12, 2015 8:11 pm)
PostPosted: Wed Aug 12, 2015 8:33 pm
What if it remains warped after thicknessing down?
PostPosted: Wed Aug 12, 2015 9:06 pm
Generally, once it's at the correct thickness, the braces and attaching it to the rims will keep the shape.
PostPosted: Wed Aug 12, 2015 11:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm holding out for pictures of the wood. This could be a lost cause.
PostPosted: Wed Aug 12, 2015 11:17 pm
Or, it could not be a lost cause. Let's see some pics and then have a second thought...
These users thanked the author meddlingfool for the post: rsfjr (Thu Aug 13, 2015 10:22 am)
PostPosted: Thu Aug 13, 2015 8:25 am
Sorry for the delay.
It is a tropical hardwood.
PostPosted: Thu Aug 13, 2015 8:26 am
Missed this one.
PostPosted: Thu Aug 13, 2015 8:33 am
I've sprayed a mist of water on the cupped side -- that tends to make the board flatten for a while, long enough to resaw.
However that board is total slab cut and its going to warp even more when thinned --- personally not something I'd use for guitar.
Ken Cierp
These users thanked the author kencierp for the post: rsfjr (Thu Aug 13, 2015 11:10 am)
PostPosted: Thu Aug 13, 2015 8:40 am
Cuped side = belly side?
PostPosted: Thu Aug 13, 2015 8:47 am
cup side --- crown side
The cupped side has shrunk because it has less moisture content than the crown side
Ken Cierp
PostPosted: Thu Aug 13, 2015 10:34 am
Definitely more flatsawn than I'd like to see, but, people do get away with using wood like that. Again, once it's thinned, braced, and glued to the box, it might be ok.
These users thanked the author meddlingfool for the post: rsfjr (Thu Aug 13, 2015 10:46 am)
PostPosted: Thu Aug 13, 2015 10:48 am
Thanks. Gonna thin it. Glue both parts to get the width and see what happens. It is hard to find quarter sawn wood around here, but since it is for my first instrument I can afford to make lots of mistakes. Lol
PostPosted: Thu Aug 13, 2015 11:07 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Since this is your first, and the wood is at hand, I see no reason to not press on and thickness this wood and reevaluate. At the very worst, you will get practice. How do you plan to thickness this wood? I used a flatsawn and cupped (though not that mmuch) walnut board for a back once and had no problem. I used a thickness sander and by the time I started getting into the range of final thickness the drum had no problem holding the back flat to the table while it sanded it. I flipped it over for every pass. Once I was at the final thickness the plate was still a bit cupped, one side cupping one way and the other book-matched half cupping the other way. Once the radiused braces were glued on and the back glued on to the arch of the rim it was fine.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: rsfjr (Thu Aug 13, 2015 11:08 am)
PostPosted: Thu Aug 13, 2015 11:10 am
Going to plane it down with a scraper plane or a toothed plane.
PostPosted: Thu Aug 13, 2015 11:15 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That will be more challenging with the sides that thick and the cups going opposite directions. But like I said, the worst that will happen is that you will get practice. . .
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: rsfjr (Thu Aug 13, 2015 11:32 am)
PostPosted: Thu Aug 13, 2015 11:33 am
A thickness sander would be nice. Did you build one?
PostPosted: Thu Aug 13, 2015 11:41 am
In theory, I would have to thickness down to 0.2" to get it flat, which is my desired thickness.
PostPosted: Thu Aug 13, 2015 11:56 am
.200 is very thick for a back, unless you mean that .200 is the thickness you want to join it at., with intent of thinning further...
These users thanked the author meddlingfool for the post: rsfjr (Thu Aug 13, 2015 12:09 pm)
PostPosted: Thu Aug 13, 2015 12:11 pm
Yes. I think it is going to be a bit difficult to glue something thinner that that. The final thickness I am aiming for is about 1/8''.
Users browsing this forum: Bing [Bot], Ken Lewis and 22 guests
