It is currently Mon Jun 23, 2025 8:47 pm
PostPosted: Fri Jun 05, 2015 8:59 pm
First name: D
Last Name: S
Not sure how to go about making one.....
I just received an LMI saw.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jun 05, 2015 9:46 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I'll take a picture of mine in the morning, Dan. Pretty low tech.
Alex
PostPosted: Fri Jun 05, 2015 10:27 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Check out KMG guitars's 'Fret Slot Spacing Jig'; they come with instructions to build a slotting jig. I have one, and it works just fine. Like the OP I started with a saw first and obtained the templates and jig afterwards. I've been very pleased and the price is realistic.
Peter Havriluk
PostPosted: Sat Jun 06, 2015 9:29 am
First name: Alex
Last Name: Kleon
City: Whitby
Here's mine, Dan. Image
The mitre box is made from hardwood scrap. The fret scale is actually for checking fret board level, but is accurately machined to scale, and the registration pin is the chuck end of a drill bit CA'd in place. Took about an hour or so to to make.
Alex
PostPosted: Sat Jun 06, 2015 11:07 am
First name: D
Last Name: S
Thanks, Alex!
Just the perfect idea I was looking for.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Jun 06, 2015 11:53 am
I highly recommend adding clamps to keep the board and template locked in place, this feature makes sawing much easier by preventing the blade from binding in the slot. Try it you'll like it!
Ken Cierp
These users thanked the author kencierp for the post: dzsmith (Sat Jun 06, 2015 7:03 pm)
PostPosted: Sat Jun 06, 2015 2:45 pm
Believe it or not, we just have the kids use an LMI fretsaw with a depth stop similar to the Stew Mac image in the guitar making woodshop class I help out in. The students mark the fret positions on both sides of the board and connect the dots with the saw. Very nice slots and a low-tech solution I wanted to mention as an alternative. If you're worried about making sure the slots are cut square, you can get the 90° guide from David Barron.
These users thanked the author James Orr for the post: dzsmith (Sat Jun 06, 2015 7:03 pm)
PostPosted: Sat Jun 06, 2015 8:59 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I recently made one similar to the one every has:
https://www.flickr.com/photos/ruby1638/ ... 776959267/
I put 2 clamps on it ( Harbor Fright, $6 each) but they are spread far enough apart that they don't both land on the FB for a couple of frets from either end. Plan accordingly
If you have a table saw or a reliable band saw, it is easy to make the baseboard and the two upright sides all as one length, then cut it in half on the TS or BS, then screw them down to another layer of baseboard squeezing the two halves together to grab the saw just the right amount. A little wax (paraffin) on the saw blade and Robert is your mother's brother.
I made my sides the right height to cut the correct depth fret slots for the StewMac steel slotting jig and a 1/4" fretboard. I can add or subtract some material for the saw to bear on if I do something different in the future.
Ed
These users thanked the author Ruby50 for the post: dzsmith (Sat Jun 06, 2015 9:32 pm)
