It is currently Sat Jun 21, 2025 10:54 pm
PostPosted: Thu Jun 04, 2015 12:55 pm
I'm getting ready to bend my first set of sides for a guitar with a florentine cutaway.
When you prep sides for florentines, do you cut the side at the florentine's point before bending? Do you leave a little excess for insurance? Or do you leave the side full length and stop the bend at the point?
Doubles sides, FWIW.
PostPosted: Thu Jun 04, 2015 1:52 pm
First name: Coe
Last Name: Franklin
City: Decatur
I did a Florentine double cutaway on a thinline jazz box a couple years ago.
I left my sides full length and bent them. Next I fit them to the mold an installed the end block. This helped me determine where the side should be cut. In my case, I was able to use the cutoffs for the cutaways after a little adjustment on the bending pipe.
PostPosted: Thu Jun 04, 2015 2:04 pm
I cut the side at the point of the cutaway before bending (draw out your pattern and figure out where that will be .. remember to have enough length in the long side piece to begin with in order to make both pieces) .. then take the cutoff and bend as required so that the grain lines will match up at the cutaway point.
PostPosted: Thu Jun 04, 2015 2:15 pm
Last Name: Kincheloe
I cut before bending, and leave a little extra. After bending, cut almost to final length, and do the miter and fine tuning by dragging on sandpaper.
PostPosted: Thu Jun 04, 2015 2:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I just bend mine on a really really, really thin pipe then sand the curve into a point.
Just kidding, of course. :)
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: James Orr (Thu Jun 04, 2015 4:35 pm)
PostPosted: Thu Jun 04, 2015 3:53 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I've heard of folks simply cutting a normal full-bend side at the desired point and flipping it over. Like Tony, I like the grain to match up, so it means two bends. I do the first with a full side to the cutaway point plus a scosh. Then I commit to the cut and bend the remaining bit the other way. I prefer not to bind the point, so I carefully fine tune the miter on a sand paper board and secure it with binding tape before gluing the joint with CA. The reinforcement of the corner is epoxied in place as soon as the CA has set.
PostPosted: Thu Jun 04, 2015 4:39 pm
Ah! Fantastic tip. Thanks, Tim. I plan to bind it, but that's still a great trick to have in the quiver. I have Rod's "Seamless Florentine" thread bookmarked. I'll have to bookmark this alongside it.
Thanks for the thoughts, guys. I was leaning towards trimming it prior to bending, and this reinforced it.
PostPosted: Thu Jun 04, 2015 4:51 pm
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
I always bend the side first. I then cut the side at the point. Hopefully, the cut off piece is long enough to finish the cutaway so the grain can be matched up. Before I cut the side, I bend most of the cutaway piece to as close as I can while still in one piece. It is hard to bend a short length of side wood. When gluing the point together, I use a small V shaped block sanded to shape to glue the inside surface of each piece to. The block makes joining the side easier. Some of the block can be cut away after the two pieces are glued. The use of a block depends on how sharp the point is. If the point is very sharp there is no need for an inside block. I'm sure there are many ways to do this. This is just the way I have always done it.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
PostPosted: Thu Jun 04, 2015 8:28 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Remember to take into account the rise of the top and back as it moves away from the point.
It needs to be wider than the the point.
Don't ask.
B
These users thanked the author Bri for the post: Bryan Bear (Fri Jun 05, 2015 9:40 am)
Users browsing this forum: Chris Ide and 45 guests
