| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Two piece side question http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=45784 |
| Author: | Steve Frady [ Mon May 25, 2015 2:20 pm ] |
| Post subject: | Two piece side question |
I need to make a set of sides be a little bit wider. I was thinking of sawing down the middle and gluing a 3/4" piece of ebony in the middle between the two halves. Could Titebond III or some other water resistant glue be used that would survive the bending process? I think I have seen a picture of this somewhere. I am hoping the collective wisdom of this forum will provide some insight. |
| Author: | Tom West [ Mon May 25, 2015 3:11 pm ] |
| Post subject: | Re: Two piece side question |
Check out Howard Klepper's "Dovetail Madness". Tom |
| Author: | Rodger Knox [ Tue May 26, 2015 11:53 am ] |
You can get an extra 3/16" at the top & bottom by gluing the linings that much proud of the sides. A strip down the middle has a good chance of looking bad, unless the depth is the same at the neck and heel. You can probably work out the geometry so that it looks OK, but it is something to consider. |
| Author: | Michael.N. [ Tue May 26, 2015 4:33 pm ] |
Hide glue will take a lot of heat, unless you use water in the bending process. Failing that powdered resin glue (urea formaldehyde) can take serious heat and it's not affected by water, which is why it's used by the boat builders. In fact I'm pretty certain it has no known solvent. It's also plenty strong enough too. |
| Author: | Steve Frady [ Thu May 28, 2015 6:41 am ] |
Pat, Your experience is encouraging. I have never heard of Lee Valley Cabinet maker's glue until now. |
| Author: | Alex Kleon [ Thu May 28, 2015 5:06 pm ] |
Steve Frady wrote: Pat, Your experience is encouraging. I have never heard of Lee Valley Cabinet maker's glue until now. I've been using it for close to 20 years, for cabinetry. I used it a couple of times for guitar repairs without any problem. It's called 202GF. Alex |
