http://www.luthiersforum.com/forum/
Drilling pegholes without a pillar drill
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=45133
Author:  Cablepuller [ Fri Feb 13, 2015 12:38 pm ]
Post subject:  Drilling pegholes without a pillar drill
Hi
Need to drill the pegholes but the money center (the wife) says we cant afford a pillar drill
is a cordless drill ok ?
If so any tips on keeping it level
Author:  ernie [ Fri Feb 13, 2015 12:55 pm ]
Post subject:  Re: Drilling pegholes without a pillar drill
use a square to align up 90 deg hole use undersized bit and have a backup piece of scrap wood clamped on headstock.(reduces splintering) Use reamer and carefully measure until you achieve perfect fit
Author:  kencierp [ Fri Feb 13, 2015 1:01 pm ]
Sure you can use a hand drill and a brad point drill -- but you also need to make the little fixture shown in this DIY video a square is not enough of a guide.
http://www.todayshomeowner.com/video/di ... lar-holes/
Author:  Cablepuller [ Fri Feb 13, 2015 1:29 pm ]
Cheers ken .. good tip
Author:  Cablepuller [ Fri Feb 13, 2015 1:42 pm ]
Ernie Do you put the scrap on the top and drill from behind or does it not matter cheers
Author:  ernie [ Sat Feb 14, 2015 5:51 pm ]
I would drill from the top with an undersized bit, and have the scrap block firmly clamped to the back . In case of small splintering, hopefully the tuner will cover the splinter or reaming out the hole from the backside will hide most of it.
Author:  bobgramann [ Sat Feb 14, 2015 8:58 pm ]
I drill all the way through with a small diameter bit. Then I use that hole to guide the larger brad point bit halfway in from each side. No breakout. If the bit is sharp, there's usually no tearout on the entry either.
Author:  Mike OMelia [ Sat Feb 14, 2015 9:26 pm ]
What is a pillar drill? Is this a Euro name for a drill press?
Author:  johnparchem [ Sat Feb 14, 2015 9:28 pm ]
This works really well if you are drilling 2 different diameters, Like a hole for the shaft and a larger one for the bushing of a tuner.
Author:  Cablepuller [ Sun Feb 15, 2015 2:59 am ]
Yes mike its a british name for drill press
Author:  Mike OMelia [ Mon Feb 16, 2015 10:13 pm ]
Got it. :)
Author:  whiskywill [ Tue Feb 17, 2015 10:57 am ]
Alternatively, raid the nearest toy box. :shock:
