Using clear grain filler on all woods? http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=45022 |
Author: | Cablepuller [ Sat Jan 31, 2015 3:15 pm ] |
Post subject: | Using clear grain filler on all woods? |
Hi Just a newbie question Can i grain fill the whole guitar with clear filler or do i need to buy the different grain fillers to match the mahogony/rosewood/spruce Thanks |
Author: | Alex Kleon [ Sat Jan 31, 2015 3:20 pm ] |
Post subject: | Re: Using clear grain filler on all woods? |
No need to grain fill the spruce top, Cablepuller. Alex |
Author: | meddlingfool [ Sat Jan 31, 2015 3:21 pm ] |
There's no reason not to use clear, unless you are specifically after the look that tinted porefill can give. Probably the most common porefill these days is clear epoxy, or epoxy that is slightly Amber. |
Author: | Cablepuller [ Sat Jan 31, 2015 3:39 pm ] |
Thanks for the advice guys . Alex the top is alpine spruce and is pretty pitted (grainy) needs something Cheers |
Author: | Rod True [ Sat Jan 31, 2015 7:48 pm ] |
You should not require any pore filler on the top. If it's pitted, sand it better! Get it flat first before you start your finishing process. Sent from my iPhone using Tapatalk |
Author: | cphanna [ Sat Jan 31, 2015 8:51 pm ] |
You've already heard it and I know you listened. But, for the benefit of lurkers, allow me to repeat: Pore filler is for open pored woods (whether that filler is clear or colored). No pore filler required on woods without open pores. Ergo, no pore filler needed on woods like spruce, maple, cherry, etc. Even if your spruce top is "grainy" (not sure what you mean by that) I am certain it doesn't need pore filler. Maybe a spit coat of shellac and then sanded back. Something like that. But it doesn't need any sort of pore filler. Just my two cents' worth, you understand. |
Author: | Cablepuller [ Sun Feb 01, 2015 3:37 am ] |
Ok thanks rod |
