It is currently Thu May 14, 2026 7:29 pm
 Post subject: Ripping CF bars
PostPosted: Thu Jan 09, 2014 8:40 am
Ripping CF bars, pretty tough to cut, blunts blades quickly I have heard, and dangerous to breath in dust I know.
I've been pointed to an economic source in EU (thanks Miguel) but would need to rip cut a 1 metre bar to get the thickness I want (3mm)
What would be the best to use?
Tablesaw (proxxon FET table saw 22mm cut) with TCT teeth (24 or 33 TPI) / Diamond coated blade (really for glass/tiles/stone)
Or
Bandsaw with TCT blade. - what kind of TPI?
To be honest, I'm leaning towards the bandsaw, but anyone got experience machining this stuff?
I would of course use a mask and run a fine air filter for this operation.
 Post subject: Re: Ripping CF bars
PostPosted: Thu Jan 09, 2014 8:52 am
Colin,
Have you asked the supplier if they will cut to the size you want? Might be a cheaper/healthier option.
PostPosted: Thu Jan 09, 2014 10:44 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I would either ask the supplier to sell you the size you want or laminate thinner pieces to reach the size you want. The last thing I would want to do is cut CF for anything other than length. Even for that I use a hacksaw, not my good woodworking blades.
PostPosted: Thu Jan 09, 2014 10:50 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Do you have a wet diamond saw? That seems like the logical choice...
Typhoon Guitars
PostPosted: Thu Jan 09, 2014 11:31 am
Or
bandsaw, diamond or TiCn coated blade, .50 X .025~.035 is good, minimum 3 teeth per thickness of cut, about 80~90 SFPM blade speed (don't use that silly feeds and speeds chart that's probably on your saw -they're almost always wrong), cool mist. air/water mixture nozzle pointed right at the cut. keeps thing chill and contains the dust. glove up, mask up, wear your goggles, and clean up the mess when you're done. let the blade do the work and keep the heat down. use a fence, run the blade guides nice and close, set the blade bearings/bushings/blocks (whatever your saw has) to minimum clearance to remove sloppiness from the set up. heat management and rigidity are really, really, important when cutting cf. your aperture plate should be in good shape as well in order to support the cut. cf is easy to deal with just take your time.
good luck!
PostPosted: Thu Jan 09, 2014 12:26 pm
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
I use a cheap wet tile saw with a diamond blade. Cuts like butter, last a long time, and no dust.
These users thanked the author twick for the post: Colin North (Thu Jan 09, 2014 1:30 pm)
Users browsing this forum: Bing [Bot] and 138 guests
