Transferring center line from neck to headstock http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=40181 |
Author: | Pmaj7 [ Thu Apr 25, 2013 9:24 pm ] |
Post subject: | Transferring center line from neck to headstock |
Anyone know a good way? Jig? |
Author: | Chris Ensor [ Thu Apr 25, 2013 9:42 pm ] |
Post subject: | Re: Transferring center line from neck to headstock |
Flexible long ruler. |
Author: | James Orr [ Thu Apr 25, 2013 10:38 pm ] |
Pat, if the headstock blank is still square, I would use a try square registered off the top of headstock. Match the two lines up. |
Author: | meddlingfool [ Fri Apr 26, 2013 12:17 am ] |
I sand flat one edge of the neck blank on the edge sander, then sand the FB and headstock plane square to that. That side becomes my reference surface. I use a square to mark the FB plane HS transition, the end of the nut slot, and the body join. Then I use one of those tools with an adjustable arm with a nail coming through it that butts against the edge of the neck. Basically it marks a small hole where you press it into the wood. The next hole will be the same distance from the surfaced edge. Two hole is the hs plane, two in the FB, connect the dots and boom" |
Author: | Dekka [ Fri Apr 26, 2013 5:22 am ] |
Near enough for jazz. (Apologies for the crude sketch) |
Author: | DannyV [ Fri Apr 26, 2013 7:42 am ] |
http://www.google.ca/search?q=centre+fi ... 77&bih=891 |
Author: | John A [ Fri Apr 26, 2013 9:10 am ] |
I just measure the centerline on the neck blank at the 12th and the 1st fret, and then at the bottom of the headstock and the top of the headstock, connect the dots. Draw line before any shaping. |
Author: | letseatpaste [ Fri Apr 26, 2013 11:08 am ] |
If one side is still straight and square, I've had great luck with one of these Incra T-rules: ![]() |
Author: | guitarjtb [ Fri Apr 26, 2013 5:56 pm ] |
Draw lines at each side of the neck at the nut, equal distances from the center line. Draw an arc from each of the points, onto the peg head. Where the two arcs intersect is the center line of the peg head. Measuring from the edge of the peg head will only work if your peghead is symetrical and the blank is squared up. James |
Author: | Bob Shanklin [ Fri Apr 26, 2013 11:49 pm ] |
http://www.amazon.com/Incra-RULE18-18-Inch-Rules-Marking/dp/B0000DD2UT Very flexible and works great for me. Bob |
Author: | Pete Brown [ Mon Apr 29, 2013 7:29 pm ] |
I can't believe that Stew-Mac haven't devised a dedicated tool for this purpose. ![]() |
Author: | Joe Sallis [ Tue Apr 30, 2013 7:28 am ] |
this thread is great- so many methods. I have to admit being a bit off sometimes when it comes to this. For me the winner is James Burkett wrote: Draw lines at each side of the neck at the nut, equal distances from the center line. Draw an arc from each of the points, onto the peg head. Where the two arcs intersect is the center line of the peg head. Measuring from the edge of the peg head will only work if your peghead is symetrical and the blank is squared up. James have to try that next time, thanks James. |
Author: | Ken Jones [ Tue Apr 30, 2013 7:59 am ] |
Todd Stock wrote: If the neck is straight, just use a combo square - adjust blade to half of neck and peg head width...mark from both sides...centered between the marks will be the center point. Works on already-shaped headstock if symmetric. If a flexible ruler is not torqued or twisted, it can be used to lay out the line. +1 |
Author: | crazymanmichael [ Tue Apr 30, 2013 8:59 pm ] |
there was ar least one purpose built tool created for this purpose by a lutherier/toolmaker in bc. lmi briefly sold his creations in the late '90's. absolutely beautiful tools at equally beautiful prices. i have no idea if he still makes them. a more reasonably priced but by no means cheap solution is the brige city tools corner square. |
Author: | Joe Sallis [ Wed May 01, 2013 7:27 am ] |
Filippo Morelli wrote: I don't understand why the arcs are helpful. Once you have a centerline on the fingerboard you can even take a sheet of paper and have a project that centerline on the peg head. Filippo Filippo, I think you're right. After writting my last post I thought about it and came to the conclusion I'm more likely to get it wrong with drawing arcs than with a ruler. |
Author: | RustySP [ Wed May 01, 2013 5:45 pm ] |
Incra flexible rules work very well and so does their centering rule. INCRA Precision Specialty Rules - 12" Precision Centering Rule Part Number: CENTER12 & CENT300M Sent from my iPad using Tapatalk HD |
