Poly Whey comments http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=39399 |
Author: | Laidback1 [ Tue Feb 19, 2013 12:19 am ] |
Post subject: | Poly Whey comments |
There was some initial buzz about Poly Whey back in January. Haven't seem anymore cooemnts recently and was wondering how its working for anyone that has used it on a guitar. Much appreciated! Mark |
Author: | SteveSmith [ Tue Feb 19, 2013 8:56 am ] |
Post subject: | Re: Poly Whey comments |
I've got it on bubinga/lutz dred and so far I like it. We will need to work with it for several years to determine if it is a good long-term finish. I find that it is easier to apply then EM6000 which is what I was using previously. I will be using it on the next 3 that I have in line right now. There are several other folks here who have used it as well. |
Author: | Laidback1 [ Tue Feb 19, 2013 9:45 am ] |
Steve, How are you applying? Spray, brush, wipe on product? Any lessons learned on the process? I've got two completed guitars to finish and am considering trying out Poly Whey.... Thanks for any info you can provide! Mark |
Author: | SteveSmith [ Tue Feb 19, 2013 9:58 am ] |
This is the thread that started it all here at the OLF: http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=38386&st=0&sk=t&sd=a&hilit=new+finish Lot's of good information including the finishing schedule I used (around pg 3) and other folks experiences as well. FYI, I sprayed the gloss furniture product thinned about 5 to 10% with distilled water. I used a Walcom EGO HVLP gun with 1.2mm tip at about 29psi. |
Author: | klooker [ Tue Feb 19, 2013 2:49 pm ] |
I'm on vacation now but plan to be in the shop by this weekend. I have a Sapele/Sitka OM that I just finished filling with Z-Poxy & will seal with shellac then finish with Poly-Whey. I've just got the hang of spraying nitro with my Fuji HVLP setup so this should be interesting. Kevin Looker |
Author: | Laidback1 [ Tue Feb 19, 2013 11:38 pm ] |
Kevin, Cool let us know how it goes.... |
Author: | SteveSmith [ Wed Feb 20, 2013 9:44 am ] |
Kevin, I think you'll be pleasantly surprised - the PolyWhey is easy to spray and builds quickly. I also think it sands easier than most other finishes I've tried but that just may be my imagination. |
Author: | Dan Pennington [ Thu Feb 28, 2013 6:20 pm ] |
I have been looking for a water based finish for both banjos and guitars and I think I've found it. Poly Whey. I bought a one pint can of it from Rockler. Comes in gloss, semi-gloss, and satin, but Rockler doesn't carry the gloss right now. Semi-gloss is shiny enough for my tastes. ![]() I applied four coats in one day. Two with a brush and two with a cloth pad. No smells. Dried in two hours or less. I mean DRY and sandable. I like it. I like the feel of the semi-gloss on a banjo neck. Should give the same good feel to a guitar neck.. |
Author: | gozierdt [ Thu Feb 28, 2013 7:58 pm ] |
I'm going to be trying it next week on a parlor guitar I'm building for my grandaughter. My local Ace Hardware is carrying it, so I assume all Ace Hardware stores will get it. |
Author: | theguitarwhisperer [ Thu Feb 28, 2013 10:59 pm ] |
A local OLF'er, mkellyvrod, stopped by my shop and dropped off the remainder of a can he was using, just' cuz he's a nice guy and wanted to let me try it out. He also took me out to lunch! I don't have a report yet on it. |
Author: | klooker [ Fri Mar 01, 2013 11:21 am ] |
I finally sprayed my first couple of coats of Poly Whey last night using my Fuji turbine unit, the little noisy one. I've only sprayed nitro before this. I thinned the Poly Whey with 10% distilled water. It's still thicker than nitro. Overall I'm pretty happy at this point. I've got some orange peel but that's my fault. It builds a lot faster than nitro. Is there any sort of apples to apples comparison between the solids content of the two or are they such different types of product that this is not applicable? Being heavier, it appears that the Poly Whey will fill pores to some extent. After the first coat, my mediocre pore filling job was revealed. After the second coat, you can't see the pores. Only time will tell after the finish dries/cures and shrinks. One of the best parts for me is that I was able to spray in my basement as opposed to my unheated garage. I'll keep you posted. Kevin Looker |
