http://www.luthiersforum.com/forum/
Proper Router Bit For Routing Slot Head?
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=39354
Author:  LarryH [ Thu Feb 14, 2013 8:02 pm ]
Post subject:  Proper Router Bit For Routing Slot Head?
Up-spiral; down-spiral; straight cut? Other? Both front and rear head stock veneers will be attached and want to use the proper bit to avoid tear-out and other such ugliness.
Author:  Alain Moisan [ Thu Feb 14, 2013 9:01 pm ]
Post subject:  Re: Proper Router Bit For Routing Slot Head?
I use a bearing guided straight cut. But I don't see why a spiral cut wouldn't work.
Author:  Josh H [ Thu Feb 14, 2013 11:07 pm ]
I general use a down cut spiral. However last time I grabbed an up cut spiral and it worked fine as well. I haven't had any issues with tear-out. I start by using a slightly oversize template guide and I cut the depth of the slots in 3-4 passes, increasing the depth with each pass. Once the slots are through the headstock, I use a smaller teplate guitar and do a full depth pass to clean up the slots.
I am using a luthiertool.com slotting setup. http://luthiertool.com/slot%20head%20fixture.html
Josh
