http://www.luthiersforum.com/forum/
Cardnial finish and sealer question
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=39350
Author:  Blake Dixon [ Thu Feb 14, 2013 12:13 pm ]
Post subject:  Cardnial finish and sealer question
I am about to make an order for Cardnial finish instrument coating. Should I only use their sealer or is everyone sealing with a spray shellac and nothing else?
Blake.
Author:  Casey Cochran [ Thu Feb 14, 2013 1:07 pm ]
Post subject:  Re: Cardnial finish and sealer question
I have only done one. Sealed the top with shellac and pore filled with Z-Poxy. No problems yet, it was sprayed last summer.
Author:  Blake Dixon [ Thu Feb 14, 2013 1:13 pm ]
Cool That is what I have planned as well, sealing with Shellac, however my question to all is (if I dont need the cardnial sealer then I wont order it.) Correct? Any advice would be appreciated.
Blake.
Author:  bluescreek [ Thu Feb 14, 2013 3:28 pm ]
You are much better off to use the proper sealer. Shellac and lacquers have changed a good bit chemically . There are many examples of adhesion issues . There is a reason they suggest using the sealers. Yes I know many of you use shellac , but it is a gamble. This is more about compatible chemistry over time.
Author:  B. Howard [ Thu Feb 14, 2013 4:10 pm ]
John is correct, modern lacquers are highly engineered coating systems, for best results you should work within the system. I even discourage using brand A sealer under brand B finish for that reason. Plus if you do have an issue the only way their tech dept. can even begin to assist you is if you used their system start to finish, anything else is an unknown.
Author:  joe white [ Thu Feb 14, 2013 10:58 pm ]
+++ What John and Brian have said. Why in the world would one compromise all the work that has gone into a guitar build and finish prep with materials that aren't formulated by the manufacturer of the finish that you use? This only opens the door to problems or complete failure. Mixing materials that aren't designed by the manufacturer for the optimal end result only invite warranty repairs that your finish supplier will not be able to support you with. Use the WHOLE system that is designed for the finish you are using and learn to use it correctly as designed.
Author:  Glen H [ Fri Feb 15, 2013 10:03 am ]
Best person to ask is Cardinal.... Seems like an easy question... "will shellac be okay under your finish?"
Author:  Darrel Friesen [ Fri Feb 15, 2013 8:45 pm ]
There are also a lot of lacquer on bare wood only finishes out there with no issues.
Author:  jsmith [ Sat Feb 16, 2013 1:00 pm ]
Darrel, I'm one of those bare wood lacquer people. Have never had any adhesion problems, and I've used Mohawk, McFadden's/Seagrave, Cardinal, and even G.J. Nikolas back in the late 70's & early 80's. If I'm not mistaken, Howard Klepper is bare-wood finisher also.
