http://www.luthiersforum.com/forum/
Martin 0-18 bridge
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=39178
Author:  coach [ Fri Feb 01, 2013 7:03 am ]
Post subject:  Martin 0-18 bridge
Does anyone out there know the original dimensions of a Martin 0-18 bridge? I'm referring to the 14 fret one that I think they made from the 30's till the early 90's. I'm most interested in the thickness of the bridge. Thanks.
Sean
Author:  coach [ Fri Feb 01, 2013 7:19 am ]
Post subject:  Re: Martin 0-18 bridge
What height did they shoot for regarding the saddle above the bridge? I've noticed for example on my Taylor guitar, the saddle is maybe an 1/8". I recently finished a guitar, and ended up making the bridge a little thinner, which made the saddle higher. The guitar still sounds better than any of my others. I use the neck jig sold by LMI to cut my dovetail, and I always use the same radius dish for my top, leaving the uper bout flat, so I think my neck angle is pretty consistent. My bridge thickness is usually around 5/16".
Sean
Author:  coach [ Fri Feb 01, 2013 8:46 am ]
Thanks Todd for the feedback.
So far I've only been making guitars for myself, and I like a very low or easy action. I guess I need to be more detailed in measuring my action, but I watched a video on LMI where Mr. O'brien demonstrates how he sets up his guitars and followed that. I've always just used my jig, and I believe my neck angle is about 2 degrees. I've tried to just get my bridge's at around 5/16" to 3/8", and then adjust my saddle accordingly.
Like I said earlier, my last guitar ended up with about a 1/4" bridge(got a little carried away trying to sand and buff it out), so the saddle ended up higher than ever. It looked kinda odd at first, especially comparing it to my Taylor and my Santa Cruz guitars. However, I had already glued up the neck, and to get the action I wanted, I couldn't come down anymore. Anyway, it still sounds amazing. I'm very pleased with it, but was trying to make my next one look a little more like most other guitars I see.
As you see, I'm just kinda bumbling along learning on my own. :)
I appreciate your time.
Sean
Author:  bluescreek [ Fri Feb 01, 2013 12:18 pm ]
the bridges spec as .325 .120 saddle
martin would hand make and size them I have seen them from 1/4 inch thick to 3/8 measured at the G string
