http://www.luthiersforum.com/forum/
What kind of fret wire for ukes, and where can I find some
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=38588
Author:  jeb98 [ Tue Dec 18, 2012 10:34 pm ]
Post subject:  What kind of fret wire for ukes, and where can I find some
I'm trying to get a soprano uke done before Christmas. I don't have any fretwire for a uke, and I'm hoping to find some thin and also softer wire. I was thinking either brass or nickle fretwire that is softer than the usual 18% would be better for the nylon strung uke. As far as size I don't have an exact preference, but I figure it should be a thinner than the .080" width that is the thinnest I have.
Does anyone know where to find fretwire suitable for a soprano ukulele, or does anyone have any they could sell me? All I really need is enough for one soprano ukulele and I'm hoping to find this ASAP.
Thanks everyone, and happy holidays.
Jonas baker
Author:  WudWerkr [ Tue Dec 18, 2012 10:48 pm ]
Post subject:  Re: What kind of fret wire for ukes, and where can I find some
what about Mandolin fret wire ? idunno
Author:  rtpipkin [ Tue Dec 18, 2012 11:21 pm ]
On the four I've made, I've used the thin .053 mando wire from stewmac.com http://www.stewmac.com/shop/Fretting_supplies/Stewart-MacDonald_Fretwire/Narrow_Fretwire.html It seems to work ok. They ship pretty quick.
Author:  DennisK [ Tue Dec 18, 2012 11:24 pm ]
That's what I use as well.
Author:  bluescreek [ Wed Dec 19, 2012 7:06 am ]
custom pearl inlay has the fretwire
Author:  ernie [ Wed Dec 19, 2012 8:13 am ]
I use uber thin mando frets
Author:  micahmed [ Wed Dec 19, 2012 9:11 am ]
Lmi has wire. But I'm learning that it's really soft. I tried using a tang nipper on it and it just kinks the wire.
Author:  jeb98 [ Wed Dec 19, 2012 2:27 pm ]
Thank you all for the tips, I'll check out those sources.
Micahmed, you mention the LMI wire is very soft, I was actually looking for softer wire because I figured with the nylon strings the softer wire would be a benefit, and I believe a lot of classical guitar builders use softer fret wire for this reason. Maybe it doesn't matter at all? I never thought about the softer wire being harder to snip with the tang nipper...
Jonas
Author:  nyazzip [ Wed Dec 19, 2012 3:45 pm ]
....sounds like you destroyed your nipper on SS wire or something.... maybe the wife borrow them to cut mosaic tile?
Author:  Pmaj7 [ Wed Dec 19, 2012 4:07 pm ]
I have used, and most newer ukes use med. I made 1 concert with SM small. It was ok. More classy looking. Very diff feel from med if yer not used to it. Also, tang niper did'nt like it. Not sure why you would want softer.
Author:  DennisK [ Wed Dec 19, 2012 5:53 pm ]
You need a tang nipper with a smaller notch in it for that tiny wire. Otherwise it tips crooked before you ever get a bite, and crimps it while cutting.
You can trim the tang with flush cut nippers rather than the special tang nipper tool, but those tend to leave a larger burr that takes more filing to smooth out.
Author:  Bryan Bear [ Wed Dec 19, 2012 7:26 pm ]
I don't get the need for soft wire for nylon strings. I can see how you can get away with softer wire, but not why you would seek it out.
Author:  Clay S. [ Sun Dec 23, 2012 7:29 pm ]
Softer wire would not be a plus. I learned on a friend's cheap guitar that had brass frets. Even with nylon strings the frets had grooves worn in them relatively quickly. The 18% nickel wire is still pretty soft compared to stainless steel, but is fine for nylon strings. Mandolin wire is just ukulele wire by a different name [:Y:]
