Radiusing http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=38119 |
Author: | Pedromas [ Wed Oct 31, 2012 9:41 am ] |
Post subject: | Radiusing |
I am building my first guitar. I'm planning on installing bracing and was wondering if I should go with a gobar and radius dishes. I was planning on doing it straight out of the Cumpiano/Natelson book by just radiusing some major braces and using clamps as this is more economical and will test my skills a bit more. Opinions please. Pete Moore |
Author: | Tai Fu [ Wed Oct 31, 2012 10:46 am ] |
Post subject: | Re: Radiusing |
Go bar decks are very useful. Radius dishes can be expensive especially for someone like me located in a place where no one makes them (so I would have to pay high costs for the dish, and the same cost for the shipping for that dish). It is worth it though, with clamps you need a huge set of various clamp, requiring something like 4 to 6 clamps (depending on the length of the brace) to clamp a single brace and its simply not a very good use of your time. By using a go bar deck you can glue on most or all of the braces at the same time, saving you a LOT of time and drastically reducing the time it takes for complication (such as humidity issues) to develop. A go bar deck can simply be 2 pieces of thick plywood, with 4 legs screwed between them. It's crude but effective. |
Author: | Trevor Gore [ Wed Oct 31, 2012 5:32 pm ] |
Pedromas wrote: I am building my first guitar... If you plan on building a second (frequently the case, planned or not!) definitely gobar deck and dishes now. |
Author: | Pedromas [ Wed Oct 31, 2012 7:16 pm ] |
Thanks for the advise. I made a gobar press and several rods out of wood strips. I read somewhere that you optimally want 5-7 lbs. of pressure per rod, is this correct? I haven't decided yet on the dishes but since I do plan on making more I'll probably get a couple. |
Author: | Blain [ Wed Oct 31, 2012 10:32 pm ] |
You can't go wrong with the gobar deck. You'll be glad you did. |
