It is currently Sun Apr 19, 2026 7:36 am
 Post subject: adjustable body forms?
PostPosted: Sat Sep 08, 2012 5:50 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I saw a post about making an adjustable body form on this forum a while ago... it looks like it would be really helpful for a luthier who builds or restores guitars of all shape and sizes. Is it simply a plywood with slots cut into it with spool clamp looking pegs locking into the slots to form the shape?
Typhoon Guitars
PostPosted: Sat Sep 08, 2012 8:19 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
here's an example of an adjustable mold that I bought from Kenneth Michael guitars. But you could make your own.
I've used it for 4 guitars, but I've come to like the standard one size molds more now.
PostPosted: Sat Sep 08, 2012 9:59 am
I've built with the Fox adjustable mold ever since taking his course 8 years ago. I like it. It would be fairly easy to build as a holding device for repairs. As a building mold you have to be more precise in the construction. You need a very accurate centerline and orientation of the end blocks as well as insuring that the posts are vertical. The end blocks also have to have the correct radius as they serve as gluing cauls for the head and tail block.
PostPosted: Sat Sep 08, 2012 11:31 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Is that workboard radiused or flat? One problem I see with the design is that I wouldn't be able to easily radius the rims for a perfect fit... at least not for the top...
Typhoon Guitars
PostPosted: Sat Sep 08, 2012 12:05 pm
The form is flat. It's actually very easy to radius. I swap out the high endblocks that were used as gluing cauls for shorter ones. Put a post in the centerline midway between the head and tail blocks and drop the sanding dish over the post. Doing the back the top sits flat on the form, when radiusing the top I put wedges under the sides as shown below so that the rimset is held in the proper position. More hassle than a conventional mold? Maybe but I've done it so much it's second nature. I do use a conventional mold for archtops and cutaways.
I do have a jig I use to sand the proper angle into the upper bout for the top and fretboard to be coplanar with the proper neck set. It gets you pretty close.
http://kennedyguitars.com/_Kennedy_Guit ... t_Jig.html
PostPosted: Sun Sep 09, 2012 12:23 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I too have a Kenneth Michael guitars mold but the one he calls the Mega Mold Guitar Making Fixture. I love the thing. It was expensive but you could build something like it yourself.
Another day, another dollar.
